Go Back   Automotive Forums .com Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-15-2009, 05:42 PM   #16
philip.zachariah
Re: 2000 Rodeo - Knocking, Rough idle, misfires, surging
Have you fixed all the problems with misfires? what all was done
philip.zachariah is offline   Reply With Quote
Old 07-19-2009, 12:30 AM   #17
Trigggl
Trigggl's Avatar
Originally Posted by dallasisuzu View Post
I'm back. I took my truck into the Aamco that did the work on my transmission a year ago and they said I've got codes for the O2 sensor, multiple misfires, misfire on cylinder 5, the solenoid something-or-other in the transmission, and god knows what else. He told me I need a tune-up and a new EGR valve. I told him I already replaced the plugs, the PCV valve, the EGR valve, and that I have a K&N air filter. His exact words were "hmmmmmm?" So, I think I need to take it to an Isuzu dealership. I'm thinking that they're the only one's who might have some kind of idea what's causing all of these problems. So, I'm right back where I started.
Interesting. How old is the K&N filter? I've got similar problems and a K&N filter. Perhaps I should remove it and see what happens. I've also heard that a clogged catalytic converter can cause similar problems, but don't quote me on it.
Greg
97 Rodeo 2.6L 2wd 5speed green and paid for
Wife's car:
06 Outback 4cyl 5speed green
Trigggl is offline   Reply With Quote
Old 07-19-2009, 10:37 PM   #18
philip.zachariah
I have a code P0300 and that tells me just misfire. I changed the spark plugs, PCV and put in a K&N filter.
But still get the code... any idea how could that be fixed..
Old 07-19-2009, 10:46 PM   #19
Trigggl
Trigggl's Avatar
Did you change the wires? I think they go bad more frequently than the plugs.
Greg
Wife's car:
Old 07-20-2009, 12:20 AM   #20
philip.zachariah
it's a 2000 model and does not have wires. I have 6 coils on top of the plugs...
Old 11-25-2009, 02:43 PM   #21
cyclone67
Did you ever get this resolved? I am having similar issues with my 2001 3.2L.
cyclone67 is offline   Reply With Quote
Old 11-26-2009, 11:52 AM   #22
hobbes69
hobbes69's Avatar
Well I'm new to this forum as I recently bought a '95 Passport (V6 4WD) with 205k miles on it. Just needed something cheap to drive to work.
I've done quite a bit of research on this as it seems my #5 cylinder just isn't doing much... anyway to your problem.
Have you Ohm'd out the coil? I recently found this site which seems to have some good info but you may end up having to take it somewhere that has the right diagnostic equipment.
Richard
hobbes69 is offline   Reply With Quote
Old 12-03-2009, 03:39 PM   #23
brokenrinker
I've been fighting this on my 2001 3.2 almost since new. I've taken it to the dealer and had the fuel pressure regulator replaced twice, fuel filter, IMG and spark plugs. I've removed and cleaned the EGR, run Sea Foam through it etc, etc. At one point it got to the point where it would hardly idle at all. That's when the dealer put the IMG on it. That fixed the major (virtually undriveable) issue but they never got rid of the intermittent P0300 code or the stumbling on cold start up.
As often as I read about this on forums I have to believe that Isuzu has a bulletin on it.
brokenrinker is offline   Reply With Quote
