Old 08-27-2010, 09:11 AM
dieseln dieseln is offline
Re: Grand Voyager Engine not turning-good starter
RIP - thank you, i'll dig into the dash today...
Old 08-27-2010, 01:17 PM
Well, I reflowed the solder joints at the multipin connector, put it back, but still no change.
Can I get a PCM from the salvage yard? No security system issues i'm assuming....
Thanks
Old 08-27-2010, 04:22 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Yes but it can be tough. You have to find the same part number PCM as the one you have and there can be more than one for a given model year.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-30-2010, 04:50 PM
I know this isn't recommended procedure but a friend lended me a PCM from a 99 strada - he said he had been able to start a jeep with it(!)
I got the same result - no crank. I was surprised that I was able to run the dash codes with it and got the same #940 and the odo mileage was the same. I thought the PCM contained the mileage.
The PCM is the thing on the driver side fender wall right?
Unsure where to go next...
Theory: Could a bad BCM prevent communication with the PCM?
Thank you for taking the time to help - I will not go to the dealer (can't afford it).
Old 08-30-2010, 04:59 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Using a PCM with a different part number, let alone from another car is iffy at best. BCM stores the mileage. BCM cause no crank? I almost don't want to say anything but it seems like I read of one instance of it on some forum some time ago. Would I spend the bucks for a new one based on that? Hell no! Yes, PCM is next to the battery on the inner fender wall. Based on the code I would trace the wiring from the PCM to the cluster looking for any kind of chaffing or pushed pins in connections etc. Check continuity. Chaffed wires are far from a rare event on these vans.
Old 08-30-2010, 06:09 PM
Any recommendation on a Manual, i.e. ALLDATA online vs. Haynes 96-00?
I'll be looking for wiring diagrams.
