| View Poll Results: To flush or not to flush autotransaxle | |||
| Yes |
2 | 25.00% |
| No |
6 | 75.00% |
| Voters: 8. You may not vote on this poll | |||
#16
Re: shifting problems???
I used to work at an oil change place (bad career move there let me tell you...) and any customer that wanted a trans flush with a vehicle that had over 80k miles had to sign a waiver that we were not responsible for any later transmission damage. That right there is enough to tell me it's a bad idea.
As Bob stated, the quicky lube trans flush/fluid exchange machines use the vehicle's trans pump to move the fluid. Therefore, any claims that they "back flush" the filter is total BS. Also, if the operator isn't paying attention and doesn't have the valves on the machine adjusted properly, it can either run the car's pan dry or overfill it causing damage to the trans. I have seen many instances where shortly after doing a flush, the trans takes a dump, where I've never seen it when a pan drop/filter change is done. The reasons vary, but the results don't lie. As I've stated before on this topic, if you wait until the trans fluid is burnt and you NEED a flush, it's too late and the flush will not help.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
#17
So if a "real" flush were to be done, there would be no need to drop the pan, correct? Everything would be done through the machine?
![]() ![]() 2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C 2000 Jeep Grand Cherokee Limited 4.7L V8 ---------------------------------------------------- 1996 Chevrolet Camaro Z28 5.7L V8 1993 Chevrolet Suburban K1500 5.7L V8 1991 Ford Probe LX 3.0 V6 1986 Ford Tempo GL 2.3L 4 cyl. |
#18
We have had ZERO failures from trans flushing. 90% of people want a trans flush when something is wrong other than that it’s out a sight out of mind. There are very few people that do P.M. most run until an issue arises then think the service or flush will be a cure all. Now keep in mind we do NOT have a flushing machine and always pull the pan first (if there is one) and if we see a problem we stop there. Another thing to avoid is the quick lube places for trans maintenance!!!.
This is not really a reply, but a question in it's self. My brother has the shifting problem. He already ran the codes check and come up with the speed sensor. I heard that 2 speed sensors on this car. Since the car mostly acts up when it is raining, we figure that it is probably the speed sensor outside of the transmission. I was wondering if anybody could tell me where this other speed sensor is at, it would be greatly appreciated.
#20
#21
And welcome to AF.
#22
I'm not a flushy person myself, so I would say no to a flush. I have heard horror stories from people who have flushed, and myself feel that if the trans fluid is changed regularily (ie pan drop) that a flush would be a wast of time.
I have however flushed tranny coolers as a process after a complete trans rebuild. No issues there. While we are on the topic of tranny's, what do you guys thing of this?.... I'm thinking about getting one for when I do my next pan drop. I like the idea of keeping the trans cooler, plus it has a drain plug for future fluid changes. http://www.zzperformance.com/grand_p...=547&catid=105
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#23
#24
Good to know Bob!. Thanks for the advice!
Tranny temps aren't an issue, and I think if I install an external cooler that it might have reverse effects during the wintertime. Just was looking into it. I will keep my eyes open for a used MSP, and look into that plug. Thanks!
#25
#26
Would you use your external cooler in conjunction with your existing one? Or bypass the one in the radiator all together? (Just curious as to the benefits of each)
#27
