Old 03-14-2009, 07:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Cavalier is overheating
I had a 96 Beretta with the 2.2L, and I got 4 bad thermostats in a row (except mine stuck open). If it opens with water, it should open with coolant... did you let it run until it almost overheated? Sometimes (but very rarely) a new thermostat will stick mostly shut until it opens/closes a few times.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-14-2009, 08:15 PM
manicmechanix manicmechanix is offline
Yeah sometimes when you refill the cooling system and don't have all the air out yet, the thermostat won't open till the car gets pretty hot and it might take a while for it to pop open. Or you could've gotten a bad thermostat as was said. It happens.
Old 03-14-2009, 11:31 PM
mexiNAMEDsqueak mexiNAMEDsqueak is offline
I had the same problem with my old car (87 Maxima) turned out to be the thermostat which someone tried dumping gunk in the fucking radiator which caused it to fucking explode. I ended up replacing the whole radiator system and it worked fine after, cost me about 400 bucks but it was well worth it. The cap was also replaced.
