Old 03-25-2009, 03:10 PM
steveb2001ZR2's Avatar
steveb2001ZR2 steveb2001ZR2 is offline
Re: 1989 1500 brake light flashing
not so lucky to have a cable, or a gear.
iam told it has to be done from the back of the cluster.
Old 03-25-2009, 04:40 PM
2000CAYukon 2000CAYukon is offline
What tranny do you have? 2wd or 4wd?
Not sure if this applies to 4wd or not but for 700r4/4l60 you should be able to change gears in the tranny to get the speedo to work right. See http://www.transmissioncenter.net/sp...__va.htm#700r4
//2000CAYukon
Old 03-25-2009, 07:06 PM
700R4-2wd from what I have came up with is the speedmeter in the cluster needs calibrated,useing a programming clip, that comes in a service kit.
As far as the trans goes, looks like the gear is on the main shaft, the speed sensor I replaced didnt have gear on it.
Old 03-25-2009, 10:00 PM
What service kit? If the kit covers 93 or newer as well, then yes (93 was the first year for 4L60E) they (4L60E) need to be reprogrammed; however, this is not true for 700r4. You will need to replace/change the gears to get the speedo correct.
Give TCI a call. http://www.tciauto.com/Products/Tech...eedo_gears.asp
//2000CAYukon
Old 03-26-2009, 04:34 PM
this is a 1989 C1500, Iam getting info from a service manual, if I know how to , or if you even can do this, I would scan the picture of it where it shows the programming clip, and where you plug it into the cuircit board to program it.
