Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 10-22-2001, 09:44 PM
FlossinPrimera FlossinPrimera is offline
Send a message via ICQ to FlossinPrimera Send a message via AIM to FlossinPrimera Send a message via Yahoo to FlossinPrimera
I thought they quit putting low ports in in 93.5 model year. When driving my rev limiter is 8000RPM (I know I've bounced off of it before). I think I got screwed, I know that the engine I have is the original because this car has been in my family since new.
1994 Infiniti G20 5 speed (rebadged as Nissan Primera)
K&N, Enkei Type 11 GML, JVC KD-SH55 Digifine, Pioneer Pear-mica components, 2 12" round things that bang and a 400W amp to make them bang. Coming soon: ACT clutch, new half-shafts, HKS superform springs, KYB AGX adjustable shocks, $tillen STB, 17" König Toxxins with Yokohama Parada Tires (P215/40R17).
http://gforces.streetracing.org/
"I wish Captian Archer was as much as a racial bigot as Captain Kirk"
-Burt Weed
Old 10-22-2001, 09:48 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Do you have a JWT ecu, or other piggyback computer? If not your tach is VERY optimistic!
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 10-22-2001, 09:51 PM
Nope, all stock computer.
Ok here is a pic of a P11 G20 (which we all know to have the high port), it has the funky cover.
-Burt Weed
Old 10-22-2001, 09:54 PM
T4 Primera T4 Primera is offline
I think you've got that backwards - the high port engines are the earlier ones. Remember, plenum/throttle body on top = lo port vs plenum/throttle body underneath = high port. P11s are LO port engines.
"The cause of liberty becomes a mockery if the price to be paid is the
wholesale destruction of those who are to enjoy liberty."
-- Mohandas Karamchand Gandhi
"They that can give up essential liberty to obtain a little temporary safety
deserve neither liberty nor safety."
-- Benjamin Franklin
"The biggest cause of trouble in the world today is that the stupid people are
so sure about things and the intelligent folks are so full of doubts."
-- Bertrand Russell
Old 10-22-2001, 09:59 PM
RYANS RYANS is offline
Send a message via AIM to RYANS
Does anyone make a cold air intake forthe high port manifold? If anyone makes a cai for it does it run to the manifold--any input will be appreciated.
Ok. now I've gone crosseyed. . .
-Burt Weed
Old 10-22-2001, 10:13 PM
Ok, here's the good oil.
The earlier engines have the high ports (where the intake runners attach to the head), and the throttle body and plenum chamber (which is what you call the funky cover) is mounted underneath the intake manifold. That is, on the high port engines, the intake manifold runners curve UPWARDS from the throttle body/plenum, and into the cylinder head intake ports.
The later low port engines have the throttle body and plenum chamber mounted on top of the intake manifold (like in the P11 pic) so that the runners curve DOWNWARDS from the throttle body/plenum chamber and into the cylinder head intake ports.
IIRC, the reason they changed the position of the intake ports in the cylinder head was because, in the newer low port engine, they could avoid having so much of the intake valve guide protruding into the intake port. This was only of limited success because the low port position meant that the intake flow had to turn 90degrees to enter the cylinder. The older high port cylinder heads allowed the intake flow to approach the intake valve at a 45degree angle.
Clear as mud??
-- Bertrand Russell
Old 10-22-2001, 10:14 PM
P10DET's Avatar
P10DET P10DET is offline
Ok, neither of those are my engine, but that is what I'm talking about, I have a 94 G20 (production date 1/94). It has a 7500RPM redline (indicative of high port, the low ports had a 7250RPM redline if I recall correctly)
OK, what would it take to convince you that's a low port?
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 10-22-2001, 10:15 PM
P10DET's Avatar
No, they stopped putting high ports in the cars beginning in 94. IOW, 94 is the first year of the low port.
George Roffe
Houston, Texas USA
00 328i
Old 10-22-2001, 10:17 PM
P10DET's Avatar
Actually, you do have an optimistic tach.
No, we all know the P11 has the low port engine.
George Roffe
Houston, Texas USA
00 328i
Ok fine its a low port, I always thought that the high ports were the newer engines. Oh well, change isn't easy.
-Burt Weed
Old 10-22-2001, 10:23 PM
Hey, we're all here to learn right? It took me a little while to get my head around too.
-- Bertrand Russell
Old 10-22-2001, 10:25 PM
P10DET's Avatar
Actually, it was for emissions reasons. The intake runners on the high port were often wet due to the placement of the runners and the injectors. They point more directly onto the runners, and thus wouldn't always get picked up by the intake air. The unatomized fuel results in poorer emissions.
I may not have explained that as well as I should have, but that's the essence.
George Roffe
Houston, Texas USA
00 328i
Old 10-22-2001, 10:31 PM
No, you explained it well. Now I'm a learnin' somethin' too.
-- Bertrand Russell
Old 10-22-2001, 10:46 PM
P10DET's Avatar
Well, Mike Kojima explained it better. He explained exactly what this did to emissions. I'm not too good at emissions (except after a few Shiner Bocks :right: ). Hell, race cars don't have emissions crap, so why should I learn about it, right?
George Roffe
Houston, Texas USA
00 328i
high port vs. low port GVR-4&a90Si Engine 1 04-29-2004 12:21 AM
Possibilities of a high port / low port head swap? ky_infiniti2000 Engine 0 04-15-2002 05:34 PM
High-Port CAI 93InfG20 Engine 10 02-09-2002 10:53 AM
WTB: 91-93 High Port Head APEXSER Classifieds 1 12-22-2001 05:29 PM
High port vs Low port.. G20er Engine 4 07-27-2001 11:07 PM
