Old 01-15-2009, 01:03 PM
00GTP*LIFER* 00GTP*LIFER* is offline
Re: Major problems??? Fuel pump or time for new computer?
I am almost certain that the pump is not cocked to one side i will check that though and maybe the fact that the o ring is probably frozen seeing as im in the garage with no heat and it is literally like -10 outside right now
Old 01-15-2009, 09:39 PM
Well after a days work and alot of breaks from the subzero weather I got the pump in and car runnig like a champ!! However one question...If I used the o ring that was on there previously which was still in great shape, is this going to be okay?! Should I probably check the fuel pressure in the morning to make sure there are no leaks?
Old 01-15-2009, 11:05 PM
doctorhrdware doctorhrdware is offline
I did when I replaced my fuel pump, not having any problems so far.
Old 01-15-2009, 11:21 PM
wlkjr's Avatar
wlkjr wlkjr is offline
You might want to fill up the tank and check for leaks around the O-ring. You'll probably be ok but leaking gas is never good, unless you like car-be-que.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 01-16-2009, 07:05 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
car-be-que, that's funny stuff Wally!
You should have got a new o-ring seal with the replacement pump. Like Wally said, I would fill the tank and then check for leaks to be safe. As long as the old seal was in good shape, you shouldn't have any issues.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-16-2009, 09:16 AM
There was a new o ring with the pump but i think the sub zero temps made it impossible to sit the pump in there.. The old ring was still in great shape and i still had to use a little vit of force to get the snap ring on i will check for leaks when i fill the tank though. You guys are life savers thanks for the advice.
Old 01-16-2009, 10:08 AM
brcidd's Avatar
brcidd brcidd is offline
I would think that with OBDII vehicles you can be sure the o-ring is sealing- because it passes the vacuum check on the fuel system- if it did not pass you would soon have a SES light and related code set for bad seal in the fuel system. Just like a loose or missing gas cap would do.....
This should give you the warm and fuzzy feeling you need about your using the old o-ring-- I would have probably done the same thing under those conditions....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
