Old 10-18-2010, 08:48 PM
mikefaster mikefaster is offline
Re: 97 Grand Caravan Power Steering pump replacement
I did mine in less than an hour... My pump was leaking a little, but I broke the plastic pulley when I changed the transmission by letting the engine hanging down too far...
I unbolted the 4 bolts and it came right out after removing the hoses... I DID press on the pulley and try to put it back in the same way and it would NOT fit...
Then I removed the pulley, and I put the pump as far into place as possible, but with the shaft pointing down, so I could press the pulley on, in the upwards direction and I just turned it 90 degrees and it went into place and I tightened the 3 bolts...
