| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
#16
Re: Pocher F40 WIP
Here are a couple of shots of the cam covers in primer... I modified them so they fit like a cam cover should. I also modified the heads so the ends of the cam bore castings stuck out from both ends of the heads with aluminum tubing, which connects to the timing belt covers on the front end. At the back are the mounts for the Magnetti Marelli cam position sensors and breather outlet and cover plates also made from aluminum tubing. Those who have built this motor with or without the Autograph TK know what the cam covers look like stock and should be able to pick out the differences. I also added the correct PCV scavenge hose tubes right above the Ferrari logos with brass tubing. Oh, and these cam covers are cast from metal, the logos filed off, P/E logos added and then textured, primed and shot with Tamiya TS-8.
![]() ![]() Stay tuned, more to come... BM1 |
#17
Re: Pocher F40 WIP
Now we start into the engine photos... I'll try to describe the changes and mods, but if you see something or have a question, just ask.
First up is a straight-on shot... water pump modified with correct outlets on front and rear of thermostat housing, Alt and A/C brackets made from brass, alternator is adjustable for correct belt tension via brass bolts, misc detailing with brass and stainless bolts washers, nuts... ![]() Next is a rear shot, showing the modified oil filter/oil pressure mount with correct pressure line outlets for the return line and feed lines for the turbos and the sending unit electrical connector, Magnetti/Marelli Cam sensor housings with electrical connectors added, breather tube with P/E clamp(still another clamp and P/E coverplate to add at bottom where it disappears into the belhousing) P/E inspection "grid" on top of bellhousing and misc nuts, bolts, washers... ![]() Now I'll just post a few more shots and you all can ask questions at will... The acorn nuts are from Marvin at Model Motorcars and a keen eye will notice the mods to the exhaust manifold flange castings on the cylinder head and the modified intake manifold mounting area. Both have been heavily modified to be more correct and I'll post pics when they are ready to fit to the motor... Enjoy again! BM1 ![]() ![]() ![]()
#18
Re: Pocher F40 WIP
Wow!
Current Builds Ferrari Enzo Ferrari 612 Ferrari F2007 Ferrari 250 Testarossa "Speed never killed anyone, it the stopping suddenly that kills you" "With every post they take off me........they take a piece of my heart" PAP 348 |
#19
Re: Pocher F40 WIP
Very nice work. Are you using resistance soldering for the brass joints and, if so, what brand/set up are you using.
Thanks in advance. |
#20
Re: Pocher F40 WIP
BM1 |
#21
Re: Pocher F40 WIP
BM1 |
#22
Re: Pocher F40 WIP
Superbly interesting WIP! Thank you. Don't be afraid to hit us with all the building details and techniques! I think I could grow to like the larger scales, seems a bit more like building something accurately than struggling to build an approximation. Well, it's all a matter of degree I guess, but anyway, fantastic stuff, keep it coming!
Mark R |
#23
Re: Pocher F40 WIP
Amazing chassis !
Re: Pocher F40 WIP
Thanks everyone, I have not made much progress over the holidays... too many things going on, but I will get some more stuff up soon. There's still a ton more to do on the chassis and engine and I have not even started on the interior or body yet. BTW, the big plan for the body is to cast the white metal in plaster sections and "lay-up" an entire new body frm a gelcoat/fiberglass composite. Much closer to the proper thickness and I can laminate it to the frame, just like Ferrari builds it! Stay tuned...
BM1 |
#25
Re: Pocher F40 WIP
Good grief! That's gorgeous
#26
Re: Pocher F40 WIP
Re: Pocher F40 WIP
Would love to hear more on some of your techniques and materials, especially the painted effects you have already achieved on the engine. Also where do you source your brass bolts from? Question regarding casting the body from the Pocher white metal body and then laying up in fibreglass.....Surely, your tubular body chassis will then be the wrong size if you then have the proper thickness??.....hope you can work that one out (no doubting you will looking at your skills). Good luck |
#28
Re: Pocher F40 WIP
So I'll use the method that I'm familiar with, which is fiberglass. I won't start the body for a bit yet, since I want to get the frame/suspension done first, but I'm sure there will be lots of eager viewers when I start in on the mold making! I may get some work done in the next few days, so stay tuned... And I'll be looking for progress on your Spyder, too!!!BM1 |
#29
Re: Pocher F40 WIP
Re: Pocher F40 WIP
BM1 |
