Old 12-31-2008, 10:24 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: p0147 code-no start/shift trouble-help meee
I assume the one I rented from auto zone is not good enough to do that?
Right!!!
MT
Old 01-07-2009, 03:48 PM
rayn3's Avatar
rayn3 rayn3 is offline
K replaced the coil fired up ran great. Sat one day and again no start with week yellow spark. Can't move it to get trans code till it starts again. Any ideas?
Old 01-07-2009, 04:02 PM
MT-2500's Avatar
AF - Advisor
Where are you testing spark?
At coil or plug wire?
Is engine craking good?
Good 12 volts ign to coil?
Try a known good coil?
MT
Old 01-07-2009, 06:33 PM
rayn3's Avatar
tested the spark at three plugs. They were all dry but had a week yellow looking spark. Put a brand new coil started up almost instantly with a turn of the key and ran great. Now about 1 day after I am back to the same thing week yellow spark from the plug wires at the spark plug end. The coil has to be good I just put it in and did the check that chilton's said to do on the coil and All came out good. The cap, wires,plugs are less then a year old. Engine is turning over free and fast. Just will not actually fire up.Not even with starter fluid. Makes me think I need to figure out what is causing this poor spark.
Any ideas?
Old 01-07-2009, 06:47 PM
MT-2500's Avatar
AF - Advisor
Check spark at coil.
Year old or brand new can be bad.
MT
