#16
Re: Lets discuss Ethanol
E-10 should not be a problem. If the engine is now running rough, it is likely due to the ethanol cleaning out the fuel system. The sediments, rust particles, additive deposits, and other random contaminants should be captured by the fuel filter. However, once the filter is slugged, or if it is damaged or inadequate to filter fine particulates, these contaminants can reach the fuel injectors and clog the inlet screens, or worse, clog the injector pintles or spray tips/orifices. I'd suspect the rough running is due to a fuel delivery problem, and not the fuel itself. If the problem persists after several tankfuls of fuel, the fuel system may need to be checked.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
#17
Alky's not a cleaner. It does attract water which will corrode your steel and aluminum parts.
#18
Nancy and Harry actually fought the farm lobbyists that promoted the tax breaks the Republicans so greedily applied for. |
#19
#20
Wow. This thread is getting political rather than helping. Come on guys, any ideas besides higher octane gas?
#21
#22
Maybe the mix is better now...I've read some stories where too much alky was put in gasoline causing problems when it was first put to use.
Just to be fair, all my gassers did fine this summer except for the garden tractor which acted like it was running lean but recovered when I pulled the choke a little...most likely the carburetor needs taking apart and cleaned. The weedeater did fine also. |
#23
(Actually, hydrazine is a liquid, but we get the idea.) The point was, and remains, that Btu energy is NOT the whole story, despite what Consumer Reports might proclaim. Quote:
As for the previous comment regarding food prices being escalated by the use of grains for fuel (I'm not sure who posted it), remember that a $4.00 box of corn flakes contains a whopping total of 14˘ worth of corn. The rest is labor, operating costs, transportation, and marketing (or greed). That was the value when corn was $4.35/bushel. and since it is now back to under $3.50, there is even less cost in that box. Did you see the prices lowered by 25%? Didn't think so. For those worried about food prices, do some more research. Given the amount of mash corn grown (which can't be used for much else) versus feed corn, the volume of feed corn hasn't been reduced enough to drive prices one way or the other. CBOT prices have been driven by the anticipated energy prices required to dry, deliver, and process grains, and not the availability of grains themselves. Stop listening to politicians and their hip-pocket news media, and start researching. Quote:
#24
Have you tested fuel pressure? Checked/changed the fuel filter? As previously mentioned, the ethanol will start cleaning out all manner of junk from the tank and lines. The filter is your first line of defense. Since the vehicle has evidently not previously used ethanol blends, this process will continue until the system is clean. Get familiar with the filter change procedure, since you might be doing it more than once until the system is clean. Don't blame the fuel. It's only cleaning out what the other fuel left in there. You should see what happens to a 1950s or 1960s vehicle when ethanol is first run through it. Been there. If there is already sediment in the injector pod inlet screens, it may be time to pull the pod and clean it. If you have to go that far, be absolutely certain you have a good filter installed, since you probably don't want to be cleaning the injector pod again. Another thing to remember is that alcohols are hygroscopic, meaning that they have an affinity for water. Given the relatively high humidity present in Florida, that means that some water will be more likely found in the fuel. Fuel tanks are vented, and some of that water will enter the fuel as it is stored. The only thing you can do to counteract that is to purchase fuel where there is a lot of traffic, and the fuel will theoretically have less time in the tanks to absorb water. Another important step is to be sure your fuel system is sealed. If you have an unsealed system, the PCM should be setting an EVAP related error code.
#25
