Old 10-23-2008, 07:31 AM
burijon's Avatar
burijon burijon is offline
Re: 2001 Intrigue - Air Pump ?
Mine does the exact same thing. Strange thing is that I just replaced mine with a brand pump less than 3 weeks ago. If y'all figure out the whole solenoid thing post up as I'd be interested in trying it. It could be a sticky if it turns out to be accurately diagnosed and fixed.
Good luck!
2005 Acura MDX 85k
2004 Acura TSX 96k
Previous 2000 Intrigue head gaskets death
Old 10-23-2008, 10:15 AM
bsansa bsansa is offline
From what I've gathered the system is rather simple:
1) Air Pump (hose connects to metal Y pipe (front/back manifolds)
2) Two vacuum driven solenoids (1 on each manifold)
3) Electric vacuum solenoid switch (under and behind top UIM cover)
(Can't miss it, it has two vacuum lines running to it and an eletrical connector)
4) Relay (passenger side just above battery)
5) Fuse
6) some vacuum lines and a couple of hoses.
Now the real question is what would command the pump back on after you start driving.
Old 10-23-2008, 08:32 PM
steffenk steffenk is offline
I have the same problem. I cannot hear the pump come back on while I'm driving, but I assume it does because the headlights flicker. There is a good post on the forum that I think explains this. Based on the info below, it seems the pump comes back on only when the passive test fails causing the PCM to run active tests.
PanzerDragon 7-12-2005 post copy and pasted below:
CIRCUIT DESCRIPTION
The AIR pump is used on this vehicle to lower fail pipe emissions on start-up. The Powertrain Control Module (PCM) grounds the AIR pump relay control circuit, which energizes the AIR pump. The PCM also grounds the AIR solenoid valve control circuit, which energizes the AIR solenoid valve. The AIR solenoid valve opens allowing manifold vacuum to open the AIR control valves. The PCM enables both control circuits when AIR system operation is desired. When the AIR system is active, the AIR pump forces fresh air into the exhaust stream in order to accelerate catalyst operation. The AIR control valves replace the conventional check valves. When the AIR system is inactive, the AIR control valves prevent air flow in either direction. DTC P0412 applies to the AIR solenoid control circuit. DTC P0418 applies to the AIR pump relay control circuit.
DTC P0410 sets if an air flow problem is detected. The PCM will run two tests using the Heated Oxygen Sensor (HO2S) voltage to diagnose the AIR system. Both tests have two parts.
The passive test is performed during regular AIR pump operation. The passive test consists of the following:
Passive Test Part 1
When the AIR system is enabled, the PCM monitors the HO2S voltage. If the HO2S voltage goes below a threshold, the PCM interprets this as an indication that the AIR system is operational.
Passive Test Part 2
When the AIR system is disabled, the PCM monitors the HO2S voltage. The HO2S voltage should increase above a threshold and switch normally.
If both of these tests indicate a pass, no further action is taken. If one of the above tests failed or is inconclusive, the diagnostic will proceed to test two. The active test is performed specifically for diagnostic purposes. Test two consists of the following:
Active Test Part 1
During this test the PCM turns the AIR system on during closed loop operation. When the AIR system is activated, the PCM monitors the HO2S voltage. If the AIR system is operating properly, the HO2S voltage should go below a predetermined threshold.
Active Test Part 2
The PCM turns the AIR system off. The HO2S voltage should return to above a rich threshold.
The PCM will repeat test two up to 4 consecutive times with a short delay between each command.
If the PCM determines that the HO2S voltage did not respond as expected during the tests, DTC P0410 will set.
CONDITIONS FOR RUNNING THE DTC
DTCs P0101, P0102, P0103, P0106, P0107, P0108, P0112, P0113, P0117, P0118, P0121, P0122, P0123, P0171, P0172, P0300, P0412, P0418, P0442, P0443, P1441 and HO2S DTCs not set.
The engine operates for more than 3 seconds .
Test 1
The engine speed is more than 400 RPM
The engine load is less than 80 percent .
The engine air flow is less than 35 g/s .
The ignition voltage is more than 11.5 volts .
The air fuel ratio is more than 13:1.
The Engine Coolant Temperature (ECT) is less than 40°C (104°F) .
The Intake Air Temperature (IAT) is more than 10°C (50°F) .
The power enrichment, deceleration fuel cut off, or catalyst over temperature not active.
The AIR system is enabled for 50 seconds . On a hot start, the AIR system operation will be delayed for 60 seconds after start-up.
Test 1 fails if:
HO2S voltage does not go below 300 mV for 25 seconds during pump operation.
HO2S voltage does not go above 600 mV during the 15 seconds after the pump is turned off.
Test 2
The engine operates for more than 5 minutes .
The engine speed is more than 400 RPM .
The EVAP purge is active
The maximum air flow is 35 g/s .
The ECT is more than 10°C (50°F) .
The fuel system is operating in closed loop.
Test 2 fails if the HO2S voltage is above 300 mV for 4 seconds during pump operation.
CONDITIONS FOR SETTING THE DTC
If the HO2S voltage does not behave as expected during either of the tests, a failure is reported.
ACTION TAKEN WHEN THE DTC SETS
The PCM illuminates the Malfunction Indicator Lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
The PCM turns the MIL OFF after three consecutive drive trips during which the diagnostic runs and passes.
A last test tailed, or the current DTC, clears when the diagnostic runs and passes.
A History DTC clears after forty consecutive warm-up cycles, if no other emission related diagnostic failures are reported.
Use a scan tool in order to clear the MIL diagnostic trouble code.
Interrupting the PCM battery voltage may or may not clear DTCs. This practice is not recommended. Refer to Powertrain Control Module (PCM) Description, Clearing Diagnostic Trouble Codes.
DIAGNOSTIC AIDS
NOTE:
Refer to Connector Test Adapter Kit J 35616-A Notice in Service Precautions.
Refer to Continuous Operation of the Air Pump Notice in Service Precautions.
Using Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you cannot duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can aid in determining how many miles since the DTC set. The Fail Counter and Pass Counter can also aid in determining how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same Freeze Frame conditions, such as RPM, load, vehicle speed, temperature, etc., that you observed This will isolate when the DTC failed.
If the problem is intermittent, refer to Intermittent Conditions. See: Diagnosis By Symptom\Intermittent Conditions
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table.
DTC P0412 AIR Solenoid Valve Control Circuit and P0418 AIR Pump Relay Control Circuit should be diagnosed first if either are set.
The AIR pump is not designed to run continuously. If the pump needs to be replaced, check for conditions that may cause continuous pump operation.
Old 10-24-2008, 12:30 PM
Great stuff. This brings me to think that my O2 sensor may be bad or going bad if it's using the readings from it to diagnose problems.
I tested all of my soleniods and they appear to be working just fine so I don't think there is a air flow problem. Unless of course my fan is "going" bad and not pushing enough air through.
Old 10-27-2008, 06:30 PM
I may have found the source of my problem. I got a vacuum pump from Autozone today (loan-a-tool) and tested both of the vacuum solenoids for holding vacuum. The driver side works great. The passenger side is another story. It won't hold a vacuum, so the internal diaphram must be bad. I'm thinking that since only one solenoid is working it must be restricting the amount of air being sent over the O2 sensor during cold starts. Since the air is more dense during cold weather, it makes sense that the pump isn't moving enough air. I ordered a new solenoid from GMPartsdirect (#12559949) so I should have it in a few days.
Old 10-28-2008, 08:51 AM
burijon's Avatar
This is fantastic! If you do find that is the source of the problem, can you please take pics and post where the solenoids are located? Yikes that solenoid is expensive!
2005 Acura MDX 85k
2004 Acura TSX 96k
Old 10-28-2008, 09:20 AM
The dealer wants $250 each. I'm trying a test. Since the diaphram in the passanger side one was broken (causing an internal vacuum leak) I disconnected the vacuum line from it and plugged the end. I think the leak was causing a weak pull on the good one which in turn would have caused the good one not to open which would have caused the pump to backup and pump to "nowhere". Now my pump sounds normal and it didn't cycle while I was driving. If this works then maybe I can get along with only one solenoid for a while. I'll know more by the end of the day.
Old 10-29-2008, 06:10 AM
Problem Solved - It was the passenger side solenoid - internal leak (Located directly under the anti-freeze fill/overflow bottle). Removing and plugging the vacuum line allowed more vacuum on the driver side solenoid which opened the valve. No more flikering lights down the street (PCM running active test) and no more check engine light. The driver side solenoid is just to the left of the air filter box. They both have a rubber hose from the "Y" pipe and a metal hose going to the exhaust manifold. You can't miss them. So, get a vacuum pump, draw a vacuum on each diaphram and see which one is causing the problem. May be able to remove and open them up and replace the diaphram? Yeaaaaah.
Old 11-03-2008, 01:16 PM
burijon's Avatar
This is great info! My SES light finally went out on its own! I wonder if the new pump just needed to take some time to 'flush' out my solenoids? Thanks for the location of the solenoids.
Right below the coolant hose is the one solenoid from your description.
2005 Acura MDX 85k
2004 Acura TSX 96k
Old 11-03-2008, 06:25 PM
Your picture shows the exact location of the driver side solenoid (great picture). The passenger side one is just below the anti-freeze fill bottle. My car is still driving great. Good news on your pump. I'd probably still see if your solenoids are holding vacuum.
Old 11-04-2008, 03:00 AM
Tobey Tobey is offline
Wow. You keep things under your hood unbelievably clean!
Your coolant surge tank is way too full btw...
Old 11-04-2008, 06:58 AM
burijon's Avatar
It's not my engine and not my picture. It's good to have reference pics though. I did just replace my recovery tank so it does look clean like that however. My front valve cover paint is all gone and chipped off.
2005 Acura MDX 85k
2004 Acura TSX 96k
Old 12-29-2008, 03:06 PM
wholebean wholebean is offline
Yes, mine also runs periodically as I'm driving. The first (original) one that was noisy did not run while driving, just the new one that I installed in March. The car runs well......the noise is just frustrating. Wish there was an answer on how to eliminate it.
Old 12-29-2008, 08:01 PM
The noise increases due to lack of air movement. Test the solenoids for holding air (get a vacuum tester from Autozone or like place). Hook the vacuum gauge to the solenoid ports and see if they hold a vacuum. I think you're going to find that one, if not both, of your solenoids has ruptured one of their diaphragms.
Old 12-30-2008, 08:47 AM
Thanks for that suggestion. It makes sense. I'll try that when I get a gauge.
