Old 11-15-2008, 04:15 PM
djjm3 djjm3 is offline
Re: 2000 blazer stuck in 4hi/auto awd
Everything is plugged in...I soldered the wires to make sure they wouldnt come apart...It shifts in all gears but buzzes going back to 2WD. but seems to work normally..........but also the it takes about 5 seconds for the "service 4wd" light to come on......before it came on right away......
Old 11-16-2008, 07:08 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Make sure you clear codes and recheck for any coming back.
That transfer case needs service with the new GM blue transfer case fluid ever so often.
If it has not been serviced service it.
Good Luck
MT
Old 11-16-2008, 02:17 PM
will do, on the codes...I changed the Auto Track II just before this went down...ill do more often from this point.....
Old 11-18-2008, 07:51 PM
For people who are trying to trouble shoot a problem like this, Start at the TCCM on 1999 and up, its on the passenger kick panel on the right side....check the terminals and make sure they are not corroded....clean them up and place anti corrosive compound on the terminal connector
