Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-21-2012, 11:24 AM
howelryan14 howelryan14 is offline
Re: 1987 Camry - No brake lights
the same damn thing happened to me. at least i have the info now to fix it. thanks!
..my single turbo Supra getting a oil change bayside ny..
Old 08-21-2012, 08:47 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
It's nice to know that the knowledge base here keeps on giving !
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 12-16-2012, 10:51 PM
Yotacamry Yotacamry is offline
This site was alot of help.i connected the wires and it worked just wish I found it sooner.those brake light switches are a pain in the butt to change I have never more frustrated with a car but thanks again for all the info definitaly helpful
Old 08-11-2013, 08:33 PM
Stovo06 Stovo06 is offline
Wow! You guys just saved me so much money, time, and frustration.
Thank you all!!!
Old 10-16-2016, 10:17 PM
craigers92801 craigers92801 is offline
it just happen to me in the mountains at night hope it works tom ty everyone
Old 01-07-2018, 04:21 PM
Sccionboxer Sccionboxer is offline
This forum is great. All the suggested ideas help a lot and save me money and time. I was able to locate the white box which in case was yellow and found the 2wires and spliced them together and it work just like explained. Thank you all for your help.
Old 03-05-2018, 09:37 AM
Lts2000ds Lts2000ds is offline
Just wanted to pop in and say a big "Thank You" to all of you that make this forum a very informative and useful site.
I was scratching my brain so hard regarding this issue that I was losing sleep over it.
Then I found this post. Took me all of 10 minutes to do the repair and "Bam"......it was fixed and all was working correctly.
Thank you....thank you....thank you.
PS.......Sleeping like a baby..........zzzzzzzzzzz.
Old 08-17-2018, 03:38 PM
let4570 let4570 is offline
Send a message via ICQ to let4570 Send a message via AIM to let4570 Send a message via MSN to let4570 Send a message via Yahoo to let4570
I own a 1990 Camry.
My brake lights stopped working.
I checked fuse, bulbs, all good. Installed new stop/break light switch under dash above brake peddle . Still no brake lights. I was getting 12 v at the break light switch. Put a gator clip jumper across the break light switch wires to insure 12 v was coming in and leaving the switch circuit .
Still no break lights. I then went online and landed on this forum I just joined. Posts on this problem spoke of a Failed Lamp Module in the trunk on left side fender well under carpet panel. I located the yellow module. I removed the circuit board to check for burned out spots as previous posts suggested . I found one burned out circuit. I took my knife blade and cleaned the black carbon residue off at the break in the circuit board. Then I took my basic type soldering iron and soldered the break back together! Reinstalled the module! Guess what?
NOW MY BREAK LIGHTS WORK AGAIN!
I found out that Toyota wants $200.00 for a new module!
Junk yards want aprox $38.00!
With this forums guidance I fixed it myself for $0.00!
MANY THANKS TO ALL WHO CONTRIBUTED TO SOLVING MY PROBLEM!
let4570
I have pics of burned out spot on circuit board and a pic of the module if you want them.
Last edited by let4570; 08-17-2018 at 03:43 PM. Reason: I have photos of circuit board burn out spot and Failed Lamp module
The Following User Says Thank You to let4570 For This Useful Post:
Brian R. (08-18-2018)
