Old 09-25-2008, 09:57 AM
j cAT j cAT is offline
Re: rear diff oil burnt! Help!
Originally Posted by dlstewart01
The G-80 is the Eaton locker. When one wheel spins 100 or so RPM faster than the other both wheels lock. They unlock over 25 MPH.
Have a good one,
Don
I have found when doing my defective park brakes that 2/3 rotations of the rear wheel with the other wheel on the ground will engage the lock....
so whenever I do the park brakes I must lift both wheels off the ground to properly adjust the shoes.......
speed is not a factor ...just simple rotation will get it to lock/unlock....
Old 09-25-2008, 10:05 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Thanks for the clarification though I'm concerned that the repair manual says it is required.
Perhaps then the opposite is true in rognmel's case...an additive was used when it shouldn't have? Think I'll stand on the sideline from now on on this topic. Thanks again for the great input.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 09-25-2008, 12:14 PM
jdmccright's Avatar
The RustBuster
Here's a thread I found that has a good explanation from Eaton on the proper lube to use and break-in procedure for new trucks:
http://www.gm-trucks.com/forums/lofi...php?t5652.html
Basically, pre-1998 axles should use mineral-based oil, not synthetic. And neither call for a friction modifier. Finally, they recommend a GL5-compliant, 70W-140 weight for heavy trailer towing.
Talk about a crash course in rear diffs....
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 09-25-2008, 12:18 PM
dlstewart01 dlstewart01 is offline
How G-80 works
http://www.youtube.com/watch?v=KbMZ9...eature=related
You can click on other G-80 videos to the right of this one.
Old 09-26-2008, 04:47 PM
I was checking your 100rpm statement....It appears that if the vehicle speed is under 20mph and there is a difference of 100rpm the rear wheels will FULLY lock....
with my problem encountered when working on the park brakes this is what is called the PARTIAL locking .. obviously the partial locking I encounted was sufficient to prevent my park brake adjustments as I could not rotate the wheel...off the ground..
above 20mph the locking is cut out ....I never knew that ....
Old 09-26-2008, 05:37 PM
bigbadram51 bigbadram51 is offline
Ahhhh....The G80 a time bomb just waiting to go off. I have seen quite a few of them grenade, most with people running over size tires. BUT have seen it on stock tires as well.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
