Old 09-17-2008, 08:43 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: cooling fans...more problems...great
Thanks for the info Bob!
And yeah, anything is possible with the PCM, but check the working and grounds for the sensor first. A flashed pcm will have the same problem as the original with the cooling system if its a wiring problem to the sensor or sensor itself.
How long has it been since the t-stat was changed?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-18-2008, 05:05 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
couldnt tell ya. but the mechanic looked at it when i changed the coolant sensor and said it was fine. unless he was wrong. i have a new one that i was about to return...should i install it?
Old 09-18-2008, 07:05 PM
tblake's Avatar
In God We Trust
Originally Posted by TDWPgtp
..... i have a new one that i was about to return...should i install it?
Why not? Its a cheap part and if yours is still the original, its time for replacement. Might just cure your problem.
