#16
Re: What kind of oil?
I've run Mobil1 since I bought my 2002 GTP new and at 97,xxx it still doesn't use even 1/2 quart between oil changes.
#17
I'm with BNaylor on that one , Mobil1 all the way.
I've had turbos on the dyno that are almost seethrough and i've never seen Mobil1 break down whereas other oils have. If you religously change your oil every 5000 km and are not racing between lights then non synthetic is fine in my opinion |
#18
Mobil 10w-30 high milaege on my 03 GP GT with 116K
2003 Pontiac Grand Prix GT 3800 Series II V6 |
#19
Have you got a smaller pulley and downpipe yet Matt? I just installed a DHP PCM from pfyc and it really woke up my GTP. especially in performance shift mode. Well worth the 200 bucks (I decided to keep my original PCM) Best thing about the DHP PCM is the fan turn on times. My car hardly ever gets above 190 degrees even in an hour of stop and go traffic. I also ordered a 2.5" bolt in downpipe from ZZP. I emailed them and they said that both the 2.5" and the 3" will bolt into stock exhaust. But I read previous posts from GTP drivers who have reported possible low end torque loss due to not enough backpressure from running the 3". So I decided to stick with the 2.5" Maybe next week I'll have an exhaust shop put it in for me. I checked and my bolts are too rusted and I'm sure I'm going to break them. Plus maybe I can pay my bill with the old cat converter since its not plugged. LOL
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#20
Ok, back on topic. I've got a qustion for you guys.
Say I've ran conventional oil in my car since I got it. Next oil change I switch to synthetic.... Do I have to now stick with synthetic or am I able to switch back? I thought I heard that once you run synthetic, you have to stick with it. Is this true? Also, I heard that there is a certain type of synthetic that conditions seals and can actually stop small oil leaks. Anyone heard of this? What brand?
#21
No that is a myth you can switch back and forth,i've never seen any issues in my career.... although it really makes no sense to do so. IMHO the key is to change the oil EVERY 5,000km or 3 mnts whichever comes first, you can push a little longer with sythetic Some of the high mileage oils have additives that soften up the seals. Most brands do some kind of High Mileage oil ,Castrol and Mobil both do. Just stay away from additives that contain ptfe,that is just evil! |
#22
what does ptfe do? and how do I know if an oil contains it or not?
Thanks for the heads up!!!
#23
http://blackstone-labs.com/dec_07_eng.html
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
#24
I've seen several high-mileage cars that developed oil leaks after the owner switched to synthetic. The theory is:
Sludge builds up over time allowing seals/gaskets to dry out due to lack of conditioning from oil. The synthetic oil helps clear the sludge which exposes dry, cracked gaskets. I'm not sure how well the seal-conditioning synthetic works. I've never tried it. |
#25
With synthetic oil the biggest issue that I know of on SII 3800 engines with high mileage are the valve stem seals. Symptoms after switching over from dino to synthetic is high oil consumption and smoking out the exhaust during startup. A few members on AF had the issue. That is why I would not do it on high mileage engines.
#26
#28
Crap, guess I shouldnt switch to synthetic then should I Bob, I've got 90,000 Miles on the clock...
I am using valvoline max life which supposidly is a synthetic blend. Got a small oil pan gasket leak, but its only down a half a quart between changes.... if that.
#29
However, if you have existing oil leaks I wouldn't switch until the respective seal or gaskets are replaced first.
#30
If there's nothing wrong with the oil you use now, why change and risk causing problems, unless you just like repairing them. To me it's kinda like not flushing an old transmission.
