| Search | Car Forums | Gallery | Articles | Helper | Quality Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
Show Printable Version | Email this Page |
#16 | |
Re: Hard start
the pump will hum for about 2 seconds prior to start up, got any friends with a pressure tester?
Life Is A Highway ,Enjoy The Ride
#17 | |
![]() Join Date: Jul 2008
Re: Hard start
sorry, I forgot to mention it was while I was driving, and it's constant. And nop...I don't know anybody with a pressure tester...guess I'm going to have to get one...
#18 | |
Re: Hard start
mybe the whirring you hear is a wheel bearing gonig bad
#19 | ||
Re: Hard start
I wanna know what the communist breakfast says to me and I wanna make sure my car doesn't follow in their footsteps. lol Seriously, haha I never heard that before!
1998 Chevrolet Cavalier Z24XR (My Baby) 1991 Toyota MR2 "When you turn your car on, does it return the favor?" -GM "What just happened?!" "You just pissed him off! That's what just happened!" In the words of the Great Fred Baboo, if all else fails, "CHEESE IT." |
#20 | ||
Re: Hard start
#21 | ||
Re: Hard start
#22 | |
Re: Hard start
Well, I changed the gas filter today and....no change
However while I was down there I realized that there was a tubbing that wasn't connected to anything that seamed to be comming from the gas pump...I'm guessing it's an air entry for vaccum (or I'm totally wrong, just taking a shot at it) because there's no other disconnected tubbing anywhere.AAnnndd the whirring noise started about 5-10 seconds after the engine was started...however it doesn't do it everytime...sometimes I just won't whir while some other time it'll do it. Also, for some wierd reason, after I'm done realiving fuel pressure to work on the fuel system the engine starts just fine....it's after it's being "used" or that pressure has been built back or something that it seams to have a hard time to start. This is really starting to confuse me.....lol Next step I guess I can try to change the MAP sensor...is it hard to remove the throttle body on a 99 2.2 OHV? (I have the Haynes manual but it seams somewhat long....just trying to plan enough time to do it) Thanks a lot to all of U who actually take the time to read this :P |
#23 | |
Re: Hard start
Sorry I get hungry, haha
#24 | |
Re: Hard start
Well, the car starts like a new one now, finally
I did two things at the same time so I'm not quite sure which one did the trick 1 - I replaced the o-rings of my injectors (I they we're still the stock ones) and speaking of which, I tested them from resistance and they all gave me either 2.6 or 2.7 and the Haynes manual said that they should be between 1.3 and 2.4 if I remember correctly....does this mean my injectors are dying? ![]() 2 - Replaced the MAP sensor (got one on ebay for 50$ isnted of 110$ at NAPA, god I love ebay :P) Sadly enough the car still makes a wierd whirring noise in the back of the car a few minutes after it's driving.....so.....beats me, guess the fuel pump has an issue or something.... |
#25 | |
Re: Hard start
You know, I wonder if maybe you should run some fuel system cleaner through your car. And with how my luck has been, I wonder if it's a small grounding issue. But idk. I swear I heard something about the higher resistance, and I'll try to figure out what it was.
#26 | ||
Re: Hard start
#27 | |
Re: Hard start
No, I was actually thinking of something like shops use like BG's fuel system cleaner. Dealerships even have it. I have never seen it used, but it's supposed to be "better" than the stuff we can get at the store.
I only thought of that because I wonder if something's clogged in there, from the fuel filter to the injectors. I've seen stuff like this in my car, but who knows, my Cavi and I make things interesting with how things get fixed, lol
#28 | ||
Re: Hard start
#29 | |
Re: Hard start
Hey, what about the ECT or the IAT? Did you take a look at them yet? Both I feel have a tendancy to be headache starters when the engine gets warm, if there's a problem around.
#30 | |
Re: Hard start
I swapped the IAT today with a new one and I got different resistance readings from the old IAT. And according to autozone, my ECT is fine.
This whole starting issue is really starting to bug the crap out of me...when I'm done changing a sensor or a part it starts just fine then a few hours after it starts doing the same damn thing... ![]() ![]() any idea if incorrectly gapped spark plugs could cause this? I'm pretty sure I gapped em right at 0.050 inches with a wire gauge... It's getting really anoying since the car starts fine sometimes and other times it doesnt... O and recently I was able 2 smell gas inside the car but only when I'm driving.... (changed IAT, MAP, FPR, Spark plugs+wires and injector o-rings) |
