Old 06-18-2008, 10:49 AM
Rolm's Avatar
Rolm Rolm is offline
Re: 99-3.8, Engine stumbles at Times
An update, I did try to clean the Mass sensor and it made it run worse, even though I was disappointed I was also encouraged that I was on the right track. I went to our local bone yard and to my surprise, I found a 2000 Impala with the complete engine I removed all the sensors just in case and once I replaced the mass sensor that was it the engine is running perfect. I guess spending the $10 to have the code read was well worth it. Toronto Guys if you want my old Mass sensor it’s yours maybe you may be able to clean it and make it work. Thanks to all for your input.
Old 06-18-2008, 03:36 PM
maxwedge maxwedge is offline
A990 racer
Make sure both seals are in place for the map sensor/pcv valve.
