Old 06-26-2008, 06:09 PM
StealthSnake36 StealthSnake36 is offline
Re: The myth about air/heat and gas!!!
its a fact with engines the more loads you put on it the more power it needs to use to work that load. the AC compressor clutch kickes on it adds a new load so more power is needed. you get more power with a higher a/f ratio, more air and more fuel. even though on highways around 45mph its in direct drive so its gets its ideal fuel economy.
Old 06-26-2008, 10:25 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
What you're not taking into account is aerodynamic load though. With windows down, there is a good chance the vehicle has a higher aerodynamic load. Whether or not that load is significant compared with the load from the A/C compressor will be vehicle dependent as well.
-Rod
Old 06-28-2008, 06:51 PM
J-Ri's Avatar
J-Ri J-Ri is offline
In my car, above 50-ish MPH seems to be better with the air on. If you have a long flat stretch of road where you are, just get going with the windows down. Once you are at a speed (hold the gas pedal steady), roll the windows up and turn the air on. If your car gains 2 mph with the same throttle, then the A/C is more fuel efficient than having the windows down.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 06-29-2008, 04:49 AM
KiwiBacon KiwiBacon is offline
A car with a real-time MPG readout would show this really easily.
Unfortunatley none of my cars do, I have a scangauge II which will plug into two of them, but the cars are too dumb to talk to it.
