#16
Re: 2000 GTP Key Stuck in Ignition Please Help!
BNaylor: I was under the understanding that the off postion was the lock postion...makes sense now. Thanks for that tblake: looks like from the scematic the neutral/park switch ties into the starting system letting you start the car in park or neutral...but has nothing to do with taking the key out of the ignition in neutral...Im with you for bypassing this whole system. Its getting old...at least to can still start your car and drive it. Ive been out for a week now...I miss it. Keep an eye on it tho if it starts to get worse might want to look at getting a new lock cylinder?
03' GTP Black on Black S&S stainless headers 3" catless to resenator JMB FWI Intense PCM Intense MPS 3.4/gatorback AL 104's 180 tstat Boost...have any? |
#17
Probably not as simple as pulling a fuse, but maybe by removing the removing the park lock actuator. Btw to everyone, when I arrived at work this afternoon, my key was stuck, so I turned it forward, then something clicked and then I was able to turn it all the way back and remove it. I had a spare set with me, so I decided to use it on the way home. So far its been driven for a few different trips with the spair set (almost 100% unused) and the key hasn't gotten stuck yet. Got a question.... If I were to replace the key cylinder, how does that work with the existing keys/door locks. I dont want to have to carry two different keys nor do I want to re-do all my locks. Is it possible to have a replacement ignition cylinder keyed to my current keys? How does this affect the Vats/PK3 system? Just Wondering..... Anyone know?
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#18
I believe if you change the lock cylinder your keys will have to be cut for that cylinder...and hate to say it but you will have to carry a key for the doors and one for the ignition...BUT if your new spare key is working then you can go to the dealership and have another keyed there. They will look at your VIN to get it keyed to your ignition.
#19
Thats what I thought. Thank you. I'm going to drive with my 2nd set for a week and see what happens.
My 1st set is 8 years old and has been use ever since, maybe he teeth are just getting wore down. Thanks Red_Tipps!
#20
On Passkey 3 and crappy Passlock systems the transponder is located in the key. Whereas Passkey 2 had the resistor pellet which was a lot easier to DIY relearn and program.
#21
Well the car went off on the tow truck this morning... Destination: Pontiac Dealer. Hopefully I should know something by the end of this week about my ignition.
Ill keep ya all posted tblake: find out anything new with your ignition issue or is the spare key still working?
#22
Any ideas what my problem is guys? Do I have to take apart the center console? How do I do that?
#23
I may be able to help, I had the identical problem that you have. I was not able to remove the key from the ignition with the shifter in park. The problem most likely is a wire that has pulled loose from the BTSI solenoid connector. The wiring harness which runs below the the shifter was not originally long enough and when moving the shifter from park to drive etc puts a strain on the wires which connect to the BTSI solenoid. The condition you describe is most likely a wire that has been pulled out of the connector for the BTSI solenoid and causing your intermittent condition of not being able to remove the key from the ignition. Several of my friends had the same problem you are experiencing. Hope This Helps Steve |
#24
Sounds like you may need to adjust your shifting linkage. take your center console out so you can get at it and see what it is doing in there. You should see the plunger retract on the solenoid when you hit park. I believe that is the "click" you hear. Tear out the console and take a look in there man.
#25
#26
There is no adjustment for the BTSI solenoid. The only adjustment for the shifter cable is for the park/neutral switch which is located on the transmission. The adjusment for the park/neutral switch is correct if the car can only be started in park or neutral. Since tblake did not mention he had a problem with this I assume that it is ok. If you remove the top piece of the console which will also remove the cup holders as this is all one piece you will see what I am talking about. The BTSI solenoid is actaully attached to the shifter which moves every time you move the console shifter to change from park to drive... etc. Very poor design, as this puts stress on the wires which hook up to the BTSI solenoid. This constant strain on the connecter at the BTSI will eventually pull a wire out of the connector leading to intemittent issues of not being able to remove the key when in park. I have had to repair this problem not once but twice now on my car. My friend had the same problem where a wire backed out of the connector. Two possible solutions, get a new wire harness for approx. 50-60 dollars or do like I did and remove the harness and splice some wire in place of where the wire broke off. The top piece of the console only takes about 10 minutes to remove the first time you do it. You start just aft of the cupholders and just to the side of where the the armrest latches into the console., There will be a small square hole which is your reference point. Using a flat bladed screwdriver about a inch to either side of the square hole gently pry up. The console cover is then slowly removed from aft to fwd. The shifter needs to be in neutral to remove the cover. There is about 4 clips which hold the assy. in place. Good Luck, Steve Last edited by srlash; 06-10-2008 at 11:38 PM. |
#27
#28
Hey guys, Thanks for all the help. I am going to make time on thursday to open it up take a look.
I'll let you know what I find out. I just hope I dont adjust something the wrong way and mess it all up. Again Thanks!
#29
It would be easier to diagnose once he gets the cover off to see whats going on in there.
I Agree, let him get in there and see what is going on. LOL tblake !!! Steve |
#30
97 Grand Prix GT 360,000 miles as of 02-01-09 391 000 miles as of 11-17-11 400,000 miles as of 3-15-13 01 Duramax/Allison 07 G6 convertible |
