Old 06-05-2008, 03:05 PM
harmankardon35 harmankardon35 is offline
Re: 2000 Intrigue No Overdrive
good point that is important to mention...the purpose of the p1811 code is supposed to tell you your shift points are off by a value greater than allowed...meaning the transmission has tried to adapt as much as it possibly can to the long shift. If the pcs was bad, then obviously the shift points will be off and you would get a p1811 (due to incorrect line pressure causing delayed shifts) but quite easily there could be true internal transmission wear causing this (or a combination of both)
