Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-29-2008, 11:42 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: new to the scene....
I'd personally get a TiAl WG and probably a cast mani or a tubular mani if you have a lot of extra cash to throw around.
WG:
http://www.maperformance.com/store/p...cat=743&page=1
Mani:
http://www.maperformance.com/store/p...cat=271&page=1
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 04-29-2008, 02:12 PM
Automotive_Fanatic's Avatar
Automotive_Fanatic Automotive_Fanatic is offline
well I plan on going all out on this ride cause I know it has potential. so which ever is better... thats the way ill go
Old 04-29-2008, 03:49 PM
also had another question.. I noticed at idle the car revs up ands down slightly... what would cause that and were is a good place to get a larger throttle body and MAF sensor?
Old 04-29-2008, 06:15 PM
Thor06's Avatar
Jizzed In My Pants
The slight up and down with the idle kind of sounds like a boost leak to me. As for the MAF and TB, search and you shall find.
Old 04-30-2008, 06:57 AM
lol ok well as for the boost leak I plan on running a FMIC w/ 3" piping.. do you think that will get rid of the boost leak? ok and lastly i just did a search on here and can not find any info on tubular manifolds .. any suggestions? also thanks for the info/ help I do appretiate it.
Old 04-30-2008, 07:34 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Unless there is a hole in your intercooler I don't see how a new intercooler will solve a boost leak problem. I would suggest making a boost leak tester. The instructions are on www.vfaq.com I did this for about 5 dollars with parts from lowes. Or you can buy one for 30 dollars from slowboy I believe.
As far as the intercooler, 2.5 inch piping will be fine. Get all new couplers and Tbolt clamps for every connection after the turbo up to the throttle body.
I've heard of alot of tubular manifolds being prone to cracking. If you could get ahold of a stock 2g manifold and port it, you will be fine and that would be cheaper in the long run.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 04-30-2008, 10:02 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Some tubular manifolds are prone to cracking. Cheap crap like pacesetter and ebay off brands will definatly crack on you.
But good brands like DNP won't crack but are pricey$$$
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-01-2008, 07:14 AM
honestly price isnt an issue cause I want it done right the first time. cause if it was done right the first time I wouldnt have to be fixing everything now... but its well worth it cause like I said before the car is in cherry condition... needs a bath but clean. I am building it to be show and go... mostly cause this will be my every day driver...otherwise I would make thisa track car...
do you have a site for DNP and a good site for a VPR
