Go Back   Automotive Forums Car Chat > Buick > Regal
Old 04-19-2008, 05:03 PM
maxwedge maxwedge is online now
A990 racer
Re: '94 Buick Regal - Problem Starting
Yup, same basic steps as #7, but seldom are they followed.
Old 04-19-2008, 07:53 PM
DJM1450 DJM1450 is offline
OK. I am going to look into getting a volt meter this week. Thanks for all the help and recommendations.
Old 04-19-2008, 08:09 PM
inafogg inafogg is offline
i no the battery was tested but.....try jumping with cables on the battery post..still sounds like low voltage
Old 04-20-2008, 10:46 PM
I tried a portable charger and made sure if was fully charged, but the starter never turned. I will try to jump it with car cables.
Old 04-22-2008, 05:10 PM
I purchased a volt meter and tested the small terminal on the solenoid starter. There was no reading on the meter. I jump started the car with cable and it started. Removed the cables and the car started. I then turned on the headlights and the car turned off. Tried to start without the cables and it would not start. Connected the jumper cables and it still would not start. Let it set for a couple of hours and it still would not start with or without cables. Another observation: When I was testing the solenoid, the fuel pump relay was clicking. Also, all the dashboard indicator lights are dim when the ignition is in the on position and the car doesnot start. When the lights are bright, the car starts. I hope this helps.
Thanks,
Dan
