Old 03-04-2003, 02:27 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
alright, for the OBD1 thing. You can either make your own harness, which takes a lot of time, and figureing out what wires are what, where they went on the OBD0 harness and where they need to go on the new OBD1 harness...a lot of bull. Or you can get on the net, and search and find someone who makes the conversion harness, that way all you have to do is plug it in. I think there is a guy on Honatech.com(someplace like that) that makes them, you might want to hit him up on it.
Alright, for the MPFI thing. Alright most cars are MPFI, but any 4th gen that isn't an Si has DPFI, i think i have that right, might not. The easiest way to tell, is look on the intake manifold, if you get a black looking thing that say PGM-FI Dual point or something like that, its a DPFI, and you will need to add some wires in to get the extra injectors working on a MPFI intake manifold. Hope i didn't loose you there. To learn what wires need to go where, go to www.4thgenerationcivic.com, ami has put up the conversion that was in the June or July issue of Sport Compact Car.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-04-2003, 02:50 PM
Mr SpiLLz Mr SpiLLz is offline
ok lol... Ill just bring it to some shop to have it done then cause im confused =/ unless its possible to buy both wires premade...
But exactly how much extra horse power/tq will the vtec give me from the same engine with vtec not enabled...?
Old 03-04-2003, 02:53 PM
Tony's Avatar
TLD Member #1
I couldn't tell you about the hp, but if you are getting someone to do it for free, it really isn't that hard to hook up the MPFI, if you want to know how to do it, pick up this months copy of Honda Tuner, the one that talks about making a Drifting Civic. It has the same article from SCC in it. If you give it to your mechanic he should be able to figure out what he has to do.
Tony
Old 03-05-2003, 02:23 AM
91civicDXdude's Avatar
Any 88-91 HF,EX, or Si has MPFI. any LX/DX has DPI
Old 03-07-2003, 10:12 AM
Tony's Avatar
TLD Member #1
Alright got another question about the trannys, what is the difference between the Z6 and a Si tranny? other than hydraulic and cable
Tony
Old 03-07-2003, 11:39 AM
different gear ratios & mounts.
Old 03-07-2003, 11:42 AM
Tony's Avatar
TLD Member #1
alright, let me rephrase that
what are the pros and cons between the two? minus the si being a simple bolt in
Tony
95 d16z6 into 91 crx si eray_92 How-To's and Walk-Through's 0 08-31-2010 04:24 PM
LSD in d16z6 transmission sohcd16beast JDM Motor & Parts info/chat 0 07-31-2010 03:10 PM
93 D16Z6 swap into 91 CRX SI, Need help riptech7 How-To's and Walk-Through's 2 01-08-2010 07:48 PM
Any good dealer with good offer for 325i in Los Angeles? oltis 3 Series 1 12-29-2003 03:50 AM
