#16
Re: clunking noise while turning
I used white lithium grease in the spray can. Easier to apply with the straw attached.
#17
Sounds like the ISS to me, too. The spray grease is a great temporary fix but I'm finding that in my case it only lasts for about a month and then I have to do it again. Takes 5 minutes but it's pretty hard on the ol'back trying to get under there. Thinking about shelling out the $$$ to have a mechanic replace it with a new one.
Good luck. Hope the spray grease fixes it for you. |
#18
i had 2 problems. The steering shaft was making most of the clunking, but there was still clunking in the wheels. The other day i started hearing a squeaking from the front wheels that sounded like brake squealers...but theres still plenty of meat on the pads. Did the turn test and i get the squeak turning right but not turning left...regardless of speed. So that combined with the wheel play and the ABS/trac lights on lead me to order up a set of new wheel hubs that come with ABS seosors. Hoping this will give me my trac control and ABS back..and stop the clunking. Just a heads up if you all have to order something give www.1aauto.com a try. I got a pair of wheel hubs for 180 bucks + 30 shipping...to order them locally...220 EACH
. They also sell the UIM for 99 bucks on the 3800's..with better egr ports to prevent melting.
#19
Hello! Im having the EXACT same problem on my 98 buick regal GS supercharger! No one can figure out whats wrong!!! What happened to be your problem, what was wrong with it? I have had mine taken to 3 mechanics and none of them can figure out what it is.. please respond ASAP! THANKS!!!
the clunking while I turned the wheels was the upper strut mount bearings...best to get complete new struts with mounts in the front end. My other problem was the wheel bearings (wheel hubs), they were worn and causing some noises, also turning on the ABS warning lights on the dash (and when the ABS warning lights turn on, the ABs system along with the 'magna steer' variable effort steering is disabled, causing the steering to be harder at low speeds). another common problem is the steering shaft making a clunking noise while turning, there is a procedure that involves lubricating the steering shaft down under the dash, however most mechanics short of a dealership know nothing of this fix (as its a pretty uncommon job to have to preform, best to 'spoon feed' the information to them in some cases)
#21
steering shaft - very common |
