Go Back   Automotive Forums .com Car Chat > Racing > Non Specific
Old 04-09-2008, 11:12 AM   #16
Gotian
Send a message via AIM to Gotian
Re: Sigh...Jetta on life support
okay well i found out how much the parts will cost me if I need to replace them, the total for the parts is going to cost around 600-800 depending how many valves and heads are damaged. Thankfully im not going to be charged for labor since my uncle is going to do the work at the shop he works at. still a freaking big chunk out of my pocket though. I'm going to kick that car in the exhaust when it gets repaired :sigh:
"Your car is a wind up toy" - Coworker into american cars
"Why cause it's an import?" - me
"No, cause its a rotary and it spins, d'uh" - coworker
Gotian is offline   Reply With Quote
Old 04-09-2008, 11:14 AM   #17
Gotian
Oh and for the VW the service manual says change the timing belt at 105k miles, what they dont tell you is to change the belt tensioner before then because it goes bad at 70k miles and eats away at the timing belt eventually snapping it earlier than when its supposed to go bad.
Old 04-09-2008, 12:55 PM   #18
Polygon
The Red Baron
Polygon's Avatar
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Originally Posted by Sleepr awd
yeah i guess it's bad when have have to carpool in an RX8. Michelle rodriguez says the car gods are unhappy with you, fix the jetta, paint it white, and watch out for the motorcyclists with automatic submachine guns.
And seriously, it does suck. almost seems too weird to be coincidence.
Yeah, two timing belts at roughly the same time. Seems very odd.
Sucks to hear that man. For a replacement I would suggest used M3.
Polygon is offline   Reply With Quote
Old 04-09-2008, 02:37 PM   #19
Gotian
In all honesty im not a big BMW fan, I like the power but I dont like the car too much. Plus its too expensive even for a used one, though I know you were joking
Old 04-09-2008, 02:42 PM   #20
BeZerK2112
380HP Isn't Enough...
BeZerK2112's Avatar
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
BeZerK2112 is offline   Reply With Quote
Old 04-09-2008, 04:03 PM   #21
Polygon
The Red Baron
Polygon's Avatar
Well you can get early 2000 models for under $20k right now, plus you can turbo charge them.
In all honesty though. I'm liking the Altima Coupe, the new Maxima is looking good, and I really do like the Mazda 3 Speed. You could always get a used S4 as well.
Old 04-10-2008, 02:17 AM   #22
Chiquae07
Chiquae07's Avatar
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
aint that a bitch. come back from a vacation and then another timing belt? must be bad timing. (ha, that was a really bad joke).
hopefully the jetta will keep its cool for a bit after its fixed, as i remember it driving you nutz trying to find a boost leak and the such before.
and onto carpooling with the rx-8, city mpg is rated 16....thats not exactly the best thing. find a 4 cyclinder beater man .
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Chiquae07 is offline   Reply With Quote
Old 04-10-2008, 03:30 AM   #23
Polygon
The Red Baron
Polygon's Avatar
One problem, I believe his engine is an interference.
Old 04-10-2008, 09:05 AM   #24
Gotian
i havent had boost leaks in the car, ive had rough idle but that was usually solved by replacing spark plugs and checking to make sure the battery was connected properly
