#16
Re: New safety Notice/Recall Buick regal
Is this an actual recall? Can I take it in now, or do I have to wait till it's official? I've had all my others done. (including the headlight) |
#17
Click here Also, GM dealers have notice of the issue by way of a Technical Service Bulletin (TSB).
#18
Knowledge can be communicated, but not wisdom! ![]() ![]() |
#19
Good to know Bo. Man this thread has so much useful information that I think we'll 5 star rate it.
![]() Quite obvious the LeSabre and PA have a different engine mounting system so that is a plus compared to the "W" bodies. As you can see by the first pic. Also, I had to remove the top ignition coil (6/3) in order to get to one of the 13mm bolts holding the aluminum engine bracket with my 13mm open/box end wrench. A socket would not fit due to the UIM clearance. If it weren't for the engine mount the job would be a breeze. The only easier engine that I know of is the GM 3100/3400 60 degree engines. On the ICM the mount I believe it was redesigned in the 1999 and up models so you can get to the far right valve cover bolt fairly easy. As you can see in the 2nd pic the remaining coils and ICM are intact with the valve cover removed. I made sure the gasket surface on the cylinder head was cleaned up for a good seal and cleaned the inside of the valve cover with the old oil sludge and varnish similar to what you did. Same for the seal groove. The gasket was an easy fit but must be inserted with the bead out. Also, I coated the gasket surface with a light coat of clean engine oil before placing it down. The gasket held good and tight without slipping off. Also, I noticed when tightening the valve cover bolts starting with the inside in a cross hatch pattern and then working out to the two outer that you will feel each bolt with new grommet bottom out and then just a short turn to the right until the torque wrench clicks off at 89 in-lbs. BTW - I used 1/4" drive tools on the valve cover bolts. ![]() ![]()
#20
Just as a FYI, I stopped by the dealer today, and they looked at mine, and it wasn't leaking. They said not to worry about it until I get the official recall notice, then bring it in. They said if it was bad, they would do it no problem. Their information is that GM is trying to get a source, and some inventory for the replacement parts. They did say that if I start smelling oil burning, to bring it right in.
Just out of curiosity, how hard is it to change the rear cover gasket on these cars? I figure if they do the front, I may do the back, just to make sure I'm good and leak free. |
#21
![]() IMO the rear is easier but the alternator has to be removed or set aside to get to the top right valve cover bolt. The other 5 are easy to get to and remove with 1/4" drive type tools. Also, you have to remove the front 02 sensor wiring harness mounting bracket from the rear exhaust manifold. Just one 13mm nut holds it on. It blocks easy removal of the rear valve cover.
