Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-30-2008, 12:23 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Throttle body repair help
The lower injector seal is a very common leak. Which is why I ordered all brand new ones . I bought the extremepsi BISS but didn't use it for the same reason. Just kept the old one in with new BISS O-ring.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 03-30-2008, 02:36 AM
ned032002's Avatar
ned032002 ned032002 is offline
I called Autozone about those o rings and they have the 4 smaller o rings for only $5.99 but I wanted to have both types or rings that needed replaced and extremepsi had it.
Old 04-03-2008, 12:51 PM
ned032002's Avatar
Replaced the Injector O-rings and no there are no boost leaks. But after a test drive I'm hitting I think fuel cut at 5500 rpms, so now I'm stumped. Any suggestions?
Old 04-03-2008, 05:29 PM
Testiklees
Make sure it's fuel cut if you haven't hit it before. You may smash your face into the steering wheel. Your boost setting might be too high, but I don't know what it's set to. Also you might want to disconnect the battery and reset the ECU. When you hit fuel cut the ECU will lower the threshold as to when it happens again.
http://www.dsmtuners.com/forums/newb...ix-merged.html
Just read through a few pages and it will give you an idea of what to look for.
Tim
1990 Talon AWD
PTE SCM5031
Old 04-03-2008, 11:03 PM
ned032002's Avatar
The first time I hit fuel cut I thought that I got whip lash, and it seems to hit around 5500 depending on WOT or not.
I'm still lost as to what I need to do to fix this problem. What would you suggest?
Old 04-08-2008, 06:24 AM
ned032002's Avatar
So my BISS screw came in that I got from that site and it's the same thing that Extreme Psi has, a plastic strew. So that was a waste, I was really hoping that they had a screw that was made of some kind of metal.
Old 04-13-2008, 10:31 AM
ned032002's Avatar
So I still can't find any dealer that sells a metal BISS. I put in the newer BISS screw and I can barely get it to start threading and it just stops and if you try to turn it the top of the screw starts breaking off. I'm getting very frustrated since this is a really shitty problem to be having. Does anyone have a BISS that's in good shape that they are willing to get rid of? I'm also going to start a thread in the classifieds.
