#16
Re: Radiator Fans
okay i dont have no kind of scanner only but the obdII scanner, but my relays working but i have rigged a wire around the smaller fan wire a hooked it up to the battery and a on/off switch both both side of the wire is disconnect will that cause the qdm 1 & 2 failure?
#17
Re: Radiator Fans
If you hooked up a jumper to ground on the fan motor, yes the QDM will give a fault. Again, the QDM sends a ground to the relay and in turn will energize the relay, which then sends voltage to the fan. If the PCM detects a break in the ground, it will set a DTC.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
#18
Re: Radiator Fans
so you saying the wire i ran from the fan to the switch (that i still have hook up to the fan motor, but off the switch) cause the qdm 1 & 2 failure? If i remove the wire thatz running with that cause the code to resolve itself? Okay what does code p1630 Battery voltage out of range mean? Is the wire causing that code too?
#19
Re: Radiator Fans
Looking at the schematic below, which wire did you cut to install a switch? Give the location and wire color if possible.
#20
Re: Radiator Fans
okay now the left cooling fan motor the line thatz going straight i did that one. and that wire is light blue. I rigged that blue wire with like a power cord you plug in the socket one end of the wire is hooked up to the switch the other end is hooked up to the positive battery and the light blue wire on the motor.
#21
“Hot wiring” the fans, is OK to test the fans, but is ABSOLUTELY not a long-term remedy. IF you use a relay with a fused jumper and eliminate the PCM control to the existing relays, you may get by with the jumper for awhile (if you remember to turn it off/on as required). The high-speed fan pulls about 18-20 amps and you could melt the wires and switch which could result in a fire.
You need to do some basic troubleshooting here and see if the PCM is providing a ground to the relay(s) when conditions dictate. Again, without the A/C on, the engine temperature must reach 212 deg before the PCM commands a ground to the low speed fan relay and 220 deg before the high-speed relay is grounded. (Use the schematic above to troubleshoot the wiring circuit). If you find that the PCM is not providing a ground to the fan relays, you can replace the PCM, or you could put your manual switch between an engine/chassis ground and the existing fan relay grounds. Finally, NEVER run a HOT (unfused) 12v jumper without a relay!!
#22
Re: Radiator Fans
how do i test to see if the pcm is providing the relays a ground? If it's not, is it hard to replace the pcm? Where is it located?
#23
Re: Radiator Fans
It is essential that you understand how a circuit works before trying to figure out why it doesn't. An electrical schematic shows the electrical current paths when a circuit is operating properly. If you have a hard time understanding basic electrical circuits, it may be best to have someone more familiar with the process do the work for you.
#24
Re: Radiator Fans
I have a obd II scanner. okay so i just can't change out the cts and the fans MIGHT work? I swear i don't wanna go through the process of changing out the pcm.
#25
Re: Radiator Fans
The diodes are used for protection of the circuit. Shorts out the reverse voltage kick commonly seen in inductive motor loads and dc motor circuits.
#26
Re: Radiator Fans
so what exactly is you suggesting i replace to make my fans work? That's the only problem i have with this car and its really upset me because i can't figure out what causing my fans not to work when the engine gets hot.
#27
Re: Radiator Fans
HotZ28 (Bo) pointed out that the engine has to reach a certain operating temperature before the cooling fans will come on with this possible exception. Is your air conditioner working? Do the cooling fans come on with the A/C set to on?
Not sure if this will work in the pre VIN "K" 3.8L engine but what happens when you disconnect the engine coolant temperature sensor (ECT)? In the later years and models the fans will come on as a failsafe when the electrical connector is disconnected at the ECT or if the PCM detects no input signal from the ECT. Just make sure ignition is set to off first before you disconnect it.
#28
Re: Radiator Fans
Yes, my ac works and yes my fans turn on when i turn on the ac, but the code qdm 1 & 2 failure comes up.
I haven't tried to disconnect the ect. Now if my fans turn on when i disconnect the ect does that mean it is bad and needs to be replaced? |
#29
Re: Radiator Fans
Won't hurt to try it just for troubleshooting purposes and to rule it. But I'm leaning towards HotZ28's (Bo) suggestion earlier which I believe PCM module due to the quad driver failure DTCs. Of course any sensor the driver's feed can cause the DTC(s) so you need to eliminate them first.
#30
Re: Radiator Fans
ok, also i failed to mention i still have the wire running from the fan to the switch still connected to the manual switch but off the positive battery will that cause the codes to come up?
