Go Back   Automotive Forums Car Chat > Cadillac > CTS and CTS-V
Old 07-10-2010, 11:41 PM
Wha Who? Wha Who? is offline
Re: How are they???
Mobil 1 is no longer the only oil brand now with the GM4718M designation.
Old 09-16-2010, 04:54 PM
azakram azakram is offline
Re: How are they???
What Kind of Engine Oil to Use
Oils recommended for your vehicle can be identified by
looking for the starburst symbol.
This symbol indicates that the oil has been certified by
the American Petroleum Institute (API). Do not use any
oil which does not carry this starburst symbol.
If you change your own
oil, be sure you use oil
that has the starburst
symbol on the front of the
oil container. If you have
your oil changed for you,
be sure the oil put into
your engine is American
Petroleum Institute certified
for gasoline engines.
You should also use the proper viscosity oil for your
vehicle, as shown in the viscosity chart.
SAE 10W-30 is best for your vehicle. However, you can
use SAE 5W-30 if it’s going to be colder than 60F
(16C) before your next oil change. When it’s very cold,
you should use SAE 5W-30. These numbers on an oil
container show its viscosity, or thickness. Do not use
other viscosity oils, such as SAE 20W-50.
GM Goodwrench oil meets all the requirements for
your vehicle.
If you are in an area where the temperature falls below
-20F (-29C), consider using either an SAE 5W-30
synthetic oil or an SAE 0W-30 oil. Both will provide
easier cold starting and better protection for your engine
at extremely low temperatures.
Old 12-12-2010, 06:08 AM
gstintraining gstintraining is offline
Re: How are they???
i am in an automotive class right now and the school has a 2009 right hand drive cts. the cts handles really well i have to say gm out did themselves with this car.
Old 12-13-2010, 01:25 PM
The_Penguin The_Penguin is offline
Re: How are they???
I just bought a 2010 CTS with AWD. So far I love this car!
Old 10-17-2012, 11:43 AM
Re: How are they???
I bought 2003 CTS 3.6, Used at 120k miles
I have done following.
Change the valve covers (oil was leaking)
Oxygen censor changed.
Timing belt with all pulleys and water pump changed.
All shocks and struts changed.
rear hub assembly changed
all tires changed
all breaks hanged.
Hacked the stereo to add AUX in it.
painted and repair the leather.
Trunk shocks changed
All plugs changed
Most work done at home Car runs like new. I love it. not to mention regular washes and waxing. Currently it is 162k
Old 10-17-2012, 11:46 AM
Re: How are they???
http://www.flickr.com/photos/9762800...n/photostream/
Old 10-17-2012, 01:05 PM
Rimmer Rimmer is offline
Re: How are they???
Originally Posted by azakram View Post
Very nice
Old 10-20-2012, 09:37 PM
skorpio1975 skorpio1975 is offline
Send a message via MSN to skorpio1975
Re: How are they???
I have read on MSN Autos that the CTS with 3.6L is the most reliable out of all Cadillacs. I'm glad that I have exactly that
