| Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
#16
Re: Enclosure and door cutting questions
200amp alt minimum? LOL
i'm runnin 1400w RMS, I bolded since he's only going to run 600 at MOST I have a 1 kinetik 800 in the back with a stock motorcraft battery up front,and the big 3 done 0 guage. I never drop below 12.5v at full tilt, thats on a stock 135 amp altenator. Theres no reason for him to go overboard and get a 200, and no reason in hell to get a 400a alt.
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
#17
Obviously mobilemom has spent some time in the shop |
#18
I trust my building skills so I think everything will be fine. I know how to add a second battery (I've done it before) but it was under the hood in a truck I've never ran one to the trunk. I thought fuses would be enough between the batteries from what I read max 18" away from each battery on positive and negative.
I've never trusted anyone to do an install for me and half the time when they do its messed up and I learn a little more fixing it. My alt can handle my current set up no problem and when I talked to Buick (Oldsmobile basically the same thing) they said a second battey would cause no real harm to my alt. Also from what I hear I can make the box look however I want it to look as long as it has the right amount of space for the subs to breath. Am I at least on the right track? EDIT: Would a speaker baffle be sufficient sound deadening? Also does this sound like a good deal I asked for a deal on a nice component setup and got this as a PM? I've got a set of MB Quart PCE-216's. It would come with all the grills and mounting hardware also. $110 shipped to your door. Also, I have a second set of MB Quarts that have been sitting around in case something went wrong with my main set. These are the same (2) 6.5" speakers, (2) 1" Tweets, but there is a Premium x-over and a Reference x-over (Main difference is the highs I believe). One of the tweets has a small dent, one of the speakers has a little stain on it, and one of the x-overs is missing 4 screws but both play fine. I don't think I have the grills or much mounting hardware for these though. I would sell these for $50 shipped to your door. If you wanted both sets I would take $150 shipped. EDIT 2:What do you guys think of this deck? http://www.crutchfield.com/App/Produ...&tp=5684&avf=N
(\__/) (='.'=) This is the original Bunny. Copy and paste bunny (")_(") into your signature to help him gain world domination *1987 Oldsmobile Ninety-Eight Regency Brougham.* (deceased) *2003 Ford Mustang GT* just a CAI and Exhaust...for now
#19
yes, box shape means little - only the internal volume counts. A speaker baffle is technically the top board of an enclosure, you must be thinking of something else.
never been much on MB Qaurt ...... some like them, some don't |
#20
I was thinking of this little foam piece that wraps around the magnet of the speaker for my mids. I was told its called a baffle maybe I heard wrong.
#21
yea, I know what you are talking about ... I think that's what they call them http://www.partsexpress.com/pe/showd...number=260-788
After looking it up, looks like I had a rather narrow view of the term. |
#22
Yes thats what I'm talking about do you think that would be sufficient protection for the speakers in the door to protect the magnet from hitting any metals and provide some sound deadening or would it be better for me to just sound deaden my doors also?
#23
Hey paul I was looking at your progress pics of your car. It looks great how much sound deadening matt did you have to use to do your entire car? Not that I think I need to do my entire car but I do have a lot of little krinks and rattles that I have to find and stop.
#24
Heres the deal, you are running 800 watts rms from the subs. But only 600 watts rms from the amp if you bridge it at 4 ohms. Anyways, to use a dual battery setup buy a battery isolator with a 200+ amp alternator input and add a properly rated FUSE less than one foot away from each of the batteries terminals. You can wire only the starter cable directly to the starting battery. As the rear battery will take most of the amp draws from the sound system, put the stronger battery in the back. Run 0 gauge between the batteries, and because the run from the back battery to the amp is going to be short, use 4 gauge for the amp because your hifonics only has a 4 awg input anyway. This will leave you ready for big power. If you want to have very good sound quality, and power, then go for JL audio w6 series subwoofers. Those are the very best subs that you will hear regardless of anything. I am getting a pair of 13.5 inch models this summer. I already made the ported box for them (3.5 cu.ft. @ 32hz). As for the alt, its not necessary to upgrade because the rear battery can handle the amperage if its backed by a cap. 120 amps is more than enough from your alt. For your speakers, make or buy MDF speaker rings, and measure & modify to suit your needs. For the enclosure, it is best to make it yourself for the spec of your subs, and space in your car. You can search around for porting instructions online.
And it seems like you will need more power from your amp; especially to drive two 12 inch solo barics. I have a monoblock MA audio anp for sale that is big on power. HK401SX 500 rms @ 4 ohm 650 rms @ 2 ohm 1200 rms @ 1 ohm 1800 rms @ 0.5 ohm it has 0 gauge inputs 8 gauge outs Look at it here: http://www.maaudio.com/product.jhtm?id=8&cid=12 It is in perfect condition and has not been used over 500 watts rms. I changed the screens lights to led's to match with the rest of the amps led's. How does $300 sound? |
#25
I know this sounds stupid, but how do you make a new thread?
#26
nice thanks for the help. I am looking into buying a better amp but right now I'm saving so I can do everything at once.
#27
O and to start a new thread go to the forum in which you want to start one and the new thread button is at the top it looks just like the post reply button you just used to reply in my thread.
#28
I am on the 7th bulk pack of dynamat xtreme, plus like 6 cans of that VB spary stuff from parts express. I think I have gone a little overboard ... but it IS a show car.
#29
There is no overboard on a showcar I'm sure all your hard work will be worth it in the end. I just hope I can figure out where all my rattles and such come from so I can fix them.
#30
Speakers have been ordered and when they get here I will try to build some mdf rings for that last little bit of clearance I need. What tools will be needed?
Do I just take some mdf and cut out a hole like I would for a sub box? If so I usually cut with a jig and clean up with a router..
