Old 02-25-2003, 10:00 PM
Modelcargarage's Avatar
Modelcargarage Modelcargarage is offline
Send a message via AIM to Modelcargarage
hey
cozmo reply to my PM about the seats
Old 02-25-2003, 10:08 PM
endlesskev86's Avatar
endlesskev86 endlesskev86 is offline
Send a message via ICQ to endlesskev86
Thanks alot guys... appreciate your help and advices... i would now buy some Tamiya compound!!! shit!! if i knew this earlier then i wouldn't have to tint the windows!!~ anyways...once i am done this kit i would TAKE PICS for u guys!!~....
O yea i might as well say this TOO...just to save SPACE and NOT get Flame
During Spring Break .... which is soon... Me, MX100 and Turbos86 are having our annual MODEL MEET!! ...LOADS and Loads of PICS for u guys!! ....can't wait now..
AF OG Dori crew (member #5)
Altezzas: It only looks good if you have the FULL car, not just the LIGHTS!! grinyes:
Old 02-25-2003, 10:21 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Well, I see you have 10 responses saying basically the same thing so I'll offer a way to prevent this from happening again...
BMF makes "black-foil" as well as the "chrome-foil". It's designed for black trim but works just as well for window edging.
My AF Classic Model Car Gallery
Old 02-25-2003, 10:56 PM
tomazws's Avatar
tomazws tomazws is offline
Send a message via AIM to tomazws
CASTRO SUPER CLEAN!
I onced messed up outlining the window for my Skyline (leaked under the masking tape)
So I dip the whole window into a cup of Castro Super Clean, let it sit for like... 2 minutes or so and rub the paint off with a Q-Tip.
I had NO problem with it. I was happy =)
-TomazWS
TomazWS.net
UF3000.com
<-- my proud lil mofo
Why don't they make ToyTaco models?!?!?! Specially the S-Runner.. ohohohh so nice :ylsuper
Old 02-25-2003, 11:22 PM
k_dog's Avatar
k_dog k_dog is offline
Send a message via ICQ to k_dog Send a message via AIM to k_dog Send a message via MSN to k_dog Send a message via Yahoo to k_dog
[quote]Originally posted by tomazws
[b]CASTRO SUPER CLEAN!
Ditto...Can't go wrong w/a little CSC. Yet when using this, be reminded that it is a very strong chemical and you should wear gloves when using it.
Old 02-26-2003, 06:50 AM
espin espin is offline
Use this stuff, works great and dosen't eat plastic or cloud it up either.
Denatured Alcohol
The safest, purest grade of denatured ethyl alcohol.
Thinning: Alcohol is used to thin shellac based products only. Use with clear or orange shellac or pigmented shellac primers. Do not use with other finishes.
Cleaning: A specialty cleaner. Use to clean painting tools after using shellac. Will soften dry or hard shellac. Can dissolve most inks, lipsticks, crayons and many other stains. General: This is the best grade of fuel for alcohol chafing dishes and stoves. Complete combustion produces no harmful gases or vapor. Alcohol is soluble in water and can be used as an anti-freeze agent. However, it evaporates rapidly and is flammable. Read cautions on the container before using.
Craig
Click here for more pics!
Old 02-26-2003, 07:41 AM
fwdfreak's Avatar
fwdfreak fwdfreak is offline
Send a message via MSN to fwdfreak
I have 2 ways
1st castrol super clean or some brake fluid and strip the shit off
2nd sand it with 800-1200-2000 and clearcoat it, atleast that worked on small cockpit windows on jets, people say that large area clearcoated will fugg it up. I donīt know if its true or not
Old 02-26-2003, 08:08 AM
Guido Guido is offline
Originally posted by COZMO6476
all you have to do is sand the area down with the highest grit you can get your hands on and then polish out the scratches with tamiya compound. be gentle since you dont want to crack it in half. ive used this technique to get rid of paint on the windshield as well as scratches that occur in the packaging. i know it sounds scary but it really does work. you then use a good wax on the window after you have painted it correctly. should be almost as good as new if you take your time and do it right. good luck
This is the only way to do it properly!
