Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-04-2003, 08:31 AM
TatII TatII is offline
ooooooo, if your talkina bout not knowing how to take the corner lamp off, its easy. like what j spec said. on the top corner of the headlight facing the fender. there is a screw. that screw keeps the corner light from falling off. so all you need to do is unscrew that one screw and you just pop the light right off. its held on by a ball cup thing that is connected to the headlight. it takes like 2 minutes to take off and put back on. its really that easy.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 03-04-2003, 10:49 AM
Fliquer Fliquer is offline
Send a message via AIM to Fliquer
OMG I want Euro lights now!! WHY DO WE GET SCREWED OVER LIKE THAT???
BTW: Are you sure the euro-spec headlights are glass? Because it seems to me that glass would be too fragile a material to put on the front of a car...one little pebble at 40mph will probably smash it.
Isitcontagious.com
'92 S13 coupe
KYB adjustable struts + Whiteline springs
Urethane bushings in all control arms and subframe
Cone Filter
Next up: LSD
RIP #05
Old 03-04-2003, 12:11 PM
J SPEC SilEighty's Avatar
J SPEC SilEighty J SPEC SilEighty is offline
Send a message via AIM to J SPEC SilEighty
yeah they are really glass.
SE-R WolfPac, Here's some pics to help you get the corner lights off so you can get the headlights off.
1. remove this screw
2. this tab is holding 2 plastic tabs on the corner light. just pull on the corner light and it will pop out from behind this tab.
3. do what I said earlier and move the corner light as far away from the headlight as you can and stick a screwdriver in between the corner light and the headlight. then push the handle of the screwdriver towards the headlight and the little ball joint thing holding the corner light on will pop out. here's a pic of where the ball joint is connected on the headlight. once you have it removed, you can get to the remaining 2 headlight screws, which can be seen in the pic.
Old 03-04-2003, 05:26 PM
Sanchi's Avatar
Sanchi Sanchi is offline
Macadamia Nut Cookies
Send a message via AIM to Sanchi
WOW thanks J SPEC, your the greates!!!! well last week i took the top screw off yanked at it till it couldnt move no more because of the top piece that had the screw. i was afrad that lil ball screw tab thingy would snap off it is plastic and all. i was useing a flathead screw driver to try to pry the sucker out just i gave up on fear of breaking it. but thankx guys now i know that is the only way to do it no fear now !!!!!
ya would still like the euro lamps
do we got anything like that at all for the s14, any diffrent headlights at all??? or are we stuck with these unless we do an entire front end conversion
:sun: :flash:
"Fear is the path to the Dark Side..., Fear leads to Anger, Anger leads to Hate, Hate leads to Suffering…" -Yoda
Old 03-04-2003, 06:10 PM
NISSANSPDR's Avatar
NISSANSPDR NISSANSPDR is offline
Send a message via AIM to NISSANSPDR
He's ok I guess
LOL jk...he's a post enthusiast over on 240sxForums so he gets all these goodies
Yours truly,
Gabriel
Clear headlights on G20 ?? SilverBeam Cosmetics 8 06-21-2002 03:45 AM
Clear headlights for Acura TL Walstylez CL | Inspire | Saber | TL 2 03-07-2002 12:06 AM
clear headlights??? krazyhatch98 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 01-17-2002 09:26 AM
Clearing Headlights on P11 hybridamp Cosmetics 1 11-24-2001 09:11 PM
