Old 03-15-2008, 10:01 AM
diggin diggin is offline
Re: 88 1/2, 5.7L Engine stalls?
Originally Posted by bearcat58
Ok, I thought we had this one nailed! I disconnected the EGR valve and plugged the hose line, started it and let it warm up. It went through all the gears ok, so I took it for spin. Seemed to run ok for a while. Got it up to 50mph on the outer roads. When I came to a stop, it would Idle as normal for a moment (30-45sec) then the it would Idle down, shutter and stall. It started up just fine. Sounds like it also has a miss.
Also, it seem that it takes a long time to rev down after sharp accel. Not the same power it had also.
You should verify the seat and plunger are clean and free of carbon and debris , you can also remove the air cleaner top and check the fuel injectors are not leaking a whole bunch of fuel by looking in the throttle body with the engine running. I had that and the throttle body base gasket leaking that was causing all types of problems. Good luck with it.
