Old 02-25-2008, 03:27 PM
natbur natbur is offline
Re: 99 Escort Not Starting
Originally Posted by Davescort97
If you've got fuel pressure at the rail and spark and compression the problem may exist with the PCM or the CKP (crankshaft position sensor)
I know it uses a combination of the camshaft position sensor and the crankshaft position sensor to determine when to fire the plugs. I'm about 99% sure the cam sensor is fine (it's brand new) but I can't say the same for the crank sensor, because I havn't managed to find a way to remove it without dismantling large portions of my engine. If the cam sensor dies, the car relies on the crank sensor only. Does the opposite also hold true?
Old 02-25-2008, 04:45 PM
Pulled the radiator to get to the Crank position sensor. Got it replaced with a new one, it was definatly having problems. The car still sounds the same though. I bring you two pieces of muti-media, a picture of the crank sensor and a audio clip of me trying to start the car.
http://www.natbur.com/junk/100_0970b.jpg
http://www.natbur.com/junk/car.mp3
Old 03-05-2008, 08:15 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
There should not have been oil on your plugs. Better do a compression test.
