Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 01-29-2008, 05:25 PM
george536's Avatar
george536 george536 is offline
Re: A few DSMlink Questions
Originally Posted by GSX RIDER
On that car part's site, is every 1995 ecu the same (the one you need for link)?
its the earlier 95, that are eprom. not all
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 01-29-2008, 07:55 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
How can you tell which ones on that site are the earlier eprom ones? should it say specifically?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 01-29-2008, 09:39 PM
steviek's Avatar
steviek steviek is offline
no not ALL 95 ecu's were eproms
You need an EPROM ecu you can check which ones are eprom via vfaq
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-05-2008, 12:05 AM
Can you get stutterbox without dsmlink? Like if you get safc?
What do you need to do to get it?
SOLD
'97 GSX
Old 02-05-2008, 02:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
You can either get another chip (which requires a socketed EPROM ECU, so you might as well do the right thing and get DSMlink) or run an aftermarket ignition box like the MSD units that have rev limiters. DSMlink provides 3 limits, max rpm limit, launch rpm limit, and shift rpm limit. If you get an ignition box, you'll wire it to the clutch switch and have to use the same RPM for both launching and shifting.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-05-2008, 10:22 AM
hmm, that sounds kind of useless...
Can anyone help me locate a 95 eprom ecu? I looked at that carparts.com site but there are a lot of them and I do not know which ones are eprom and which aren't.
SOLD
'97 GSX
Old 02-05-2008, 01:25 PM
steviek's Avatar
I see them for sale on dsmlinkforums all the time. Of course you don't have access but I might still be able to put you in contact with someone. Pm me if you are serious.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
