Old 01-29-2008, 07:29 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 01 No Start Got Fuel,spark,compresion
Have you tried swapping the entire distributor?- based on the information below- I'd try that next.....you may have a CKP signal- but may not be valid....
This electronic ignition system is known as a high voltage switch (HVS) distributor ignition system. Trigger information is supplied only by the CKP sensor. The CMP (HVS) is located inside the distributor, and is used for fuel injector sequencing and misfire diagnosis. There is no back-up or by-pass system used, so the engine will not run without a valid CKP input. The PCM signals the coil to fire through the IC module. The resulting secondary energy is distributed to the spark plugs by a conventional distributor cap and rotor assembly
CMP Sensor (HVS) in Distributor
The CMP sensor is located in the distributor base. The distributor is driven by the camshaft and distributes the secondary voltage to the spark plugs through the distributor rotor, cap, and wires. The CMP sensor produces a signal once every revolution of the camshaft. The CMP signal identifies the position of the #1 cylinder relative to the crankshaft
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 01-30-2008, 02:46 PM
hog buff hog buff is offline
entire distrib has been changed with a known good and both cam /crank sensors are new from gm the van will not run long enough to do a cam/crank sync all with no change
