Old 01-30-2008, 11:08 AM
xjcamaro89 xjcamaro89 is offline
Re: 2002 Silverado After a Transgo Kit
Ya, i know how to take it out i had it out on monday, i was just saying the honeycomb screen doesnt come off like in other gm cars so you can gently clean the wires with a q-tip like i have done in the past. Thanks!
Old 01-30-2008, 01:50 PM
j cAT j cAT is offline
I 'm surprised that you are not aware that no touching of these wires is allowed as they can be damaged with any movement. you are supposed to use an appoved cleaner like crc maf cleaner to be used to clean maf's anyother cleaner is damaging . you simply install the straw to spray head and give the wires a good spray. you do not touch wires at all......also if the maf was totally removed from air ducting how is is you did not have a clear view access to the wires? the intake manifold side is the side that the wires should be in clear view.
Old 01-31-2008, 07:17 AM
Go take a look through the s-10 blazer forums thats all they talk about is taking the MAF apart to clean it, the blazers get so bad that there is a thick black build up on the wires. I know that the wires are very delicate, and that a replacement part is very expensive. Thats why i said "gently" clean the wires, and no the engine intake side of the MAF doesnt give you a clear view of the side of the wires that get covered in gunk, its the filter side of the MAF that gets covered in gunk, and on that side of the MAF is a honeycomb screen that makes it very difficult to look down through and tell if there is a build up on the wires. On the blazers there were 4 screws that allowed you to remove that screen to easily clean the wires, i have done this on many blazers and monte carlos so please dont preach to me about what you think i can be doing to my MAF, cause ive been cleaning MAFs for quite a while and have not hurt one yet, unless you consider a better running car hurting the MAF. Thank you!
Old 01-31-2008, 11:36 AM
are we talking about a 2002 silverado? if the intake manifold side of the maf does not allow free and clear view of the small sensing wires then it's installed backwards or it is the wrong maf.......also I have no problems if you use the wrong method or chemicals in this proceedure as you will be opening your wallet.
Old 01-31-2008, 11:48 AM
When you say intake side of the MAF do you mean engine intake as in the Throttle Body side of the MAF or when you say intake do mean the side of the MAF that takes in the air. Because the engine/ throttle body side of the MAF does have open access to the wires, but it is the wrong side of the wires that get dirty, the air filter/box side of the MAF has a honeycomb screen on it to keep chunks from coming through and hitting those wires, and the screen is not removeable so the only way to clean it would be with a spray.
Old 01-31-2008, 11:56 AM
the wires must be clean. my wires looked clean, my air filter side was clean also. but after i used the spray as a forum member recommeded and after internet searches and other articles on the maf operation i found that a film that can't even be seen will cause problems like yours. after i cleaned my maf the engine was very responsive to throttle changes and this i noticed at hyway speeds.....
Old 01-31-2008, 12:07 PM
ok, can i get the MAF cleaner at Advance Auto Parts? Im going to do it tonight.
Old 02-01-2008, 08:14 AM
Ok, i got some MAF cleaner last night and cleaned my MAF. i can notice a slight difference in the smoothness that the engine runs and maybe a slight difference in shifting, let me ask you this, i have done alot of chip tuning with TBI cars, and im sure the computers still work somewhat the same way, so, when doing a mod or cleaning something that would affect the computer like cleaning the MAF so it changes what the computer sees as far as air flow goes, does it take a couple cycles through open and closed loop in the computer for it to learn what has happened and adjust itself. I know when i program a new chip the changes are instant, but you do notice after you drive is a couple times your computer smooths itself out, so with all that being said, would my truck run a little better after i cleaned the MAF, after i cycle it though open and closed loop a couple times, and the computer teaches itself? Just a question? But i did notice a slight difference, but nothing like when i cleaned the MAF on my 2000 blazer, oh my! the wires were completely black and had a black gunk build up on them, when i would start out at a dead stop with the blazer before i cleaned the MAF, it would almost stall out a couple times, then i pulled the MAF and cleaned it and it was like night and day! It actually felt (no kidding or exageration) like i pulled the old motor and installed a brand new bigger and better one, thats how bad the MAF was dirty, and how bad it made the engine run! So anyway, i had nothing against cleaneing the MAF, or disbeleif in what you guys were saying before cause i know first hand how a dirty MAF can F things up, but I couldnt clean it the way i cleaned other ones.
Old 02-01-2008, 02:51 PM
there is no learning . this is simply a sensor just like any other sensor it measures something. the maf measures air flow and if it does not correctly report to PCM the correct amount of air entering the engine it cannot properly manage the fuel mixture. so it is on these engines very important that this be cleaned even if it looks clean. i have not yet determined how often this should be done or how to measure for proper maf operation to determine clean intervals. but i'm gonna do the maf when air filter needs servicing and see how that works out.
Old 02-04-2008, 07:20 AM
On the MAF cleaner can it said for best results clean the MAF everytime you change the air filter.
Old 02-04-2008, 08:47 PM
so what about the shift problem ? has it been running ok?
Old 02-05-2008, 07:22 AM
Its not bad, cleaning the MAF maybe corrected the shift problem slightly. I think i just might be expecting too good of shifts from this truck, ive never had a truck with an automatic and my last two cars have been SUV's. Am i wrong to think that my tranny should shift like it would if i was in a car? i might just have a normal shift and not know it. Anyway. Thanks!
Old 02-05-2008, 09:33 AM
When my 2000 sil was new, my first truck, i noticed that it had a slower shift. this was ok with warm temps , but as cold weather arrived i did not like it. too slow for me. so i did a little research and found that synthetic would speed up shifting. when winter arrived and the temp was 6 below the transmission shifted normally and that is when my other vehicle was converted to mobil synthetic. the fluid also can take more heat than non synthetic and it definitly has a faster solid shift . this is very noticable at hyway speed when passing. it now sells for 8.oo quart and you will need 12quarts to get most of the old fluid out.
Old 02-06-2008, 12:46 AM
Tdragone Tdragone is offline
I know I'm going to regert saying this.. I just paid mine off; but my '02 with the 4.8 has NEVER had the funky clunks shifting to-from ANY gear.
I am curious though.. My truck has not ever been to a chevy dealer since I bought it. I wonder how much of this could be bad firmware updates through the years? I test software for my day job; so these are the things I wonder about...
Old 02-06-2008, 07:23 AM
ok, here in PA we have had a string of warmer weather (40-50*) and i have noticed just today with the warmer temp that it shifted pretty good, i got the truck in october and the weather got cold right after that and hasnt been this warm since, i thinking that i might just have a slower shift in the cold, also this only happens at lower speeds, and if you were driving the car that is exactly what it feels and sounds like, a real slow shift, if i give it some peddle at acceleration i dont get the weird shift, its only at low acceleration speeds. What exactly would i have all to do to change to synthetic? I just had a new filter put in, in december when the transgo kit was put in so i dont think i need a filter. how would i get all the old fluid out successfully? thanks!
Also about the firmware update, is there a way that i could use my laptop to install original firmware, i have cables and software to read ECM's from my laptop, i have datalogged and burned chips for Thirdgen camaro's with TBI systems, i know that these ECMs are writeable so does anyone happen to know what program to use and where i could get the firmware from, thanks!
