Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 01-28-2008, 10:23 AM
Im Lon 2 Im Lon 2 is offline
Re: Transmission or sensor?
Originally Posted by tirwin88
Chevy did confirm it and I was told it would be an issue later on because they fixed the problem.
Would be?
Old 01-28-2008, 01:14 PM
j cAT j cAT is offline
Originally Posted by Im Lon 2
It is also idling lower when in Park then Jumps from 800 RPM's to 600 then right back to 800 RPM's.. It use to Idle around 900-1000.
you need a repair shop to checkout your vehicle, as you have many issues. find an honest highly recommended auto repair shop and have them inspect and give solid repair quotes..........
Old 01-28-2008, 02:18 PM
I just got back.. I was told before I even think about fixing the CAT I need to have my lower intake fix. I'm leaking oil/antifreeze. He said if there is something wrong with the CAT and I fix it now, that this one will probably go out again with that leaking. Does that sound like an Honest reply? He cave me a cost of $700 to have the Lower intake Gasket replaced?
Old 01-28-2008, 04:31 PM
i'm very confused as now , you are taking manifold leaks. so let's see cv joints, cat, transmission, manifold.this is adding up to a large amount of money.....If the dealership stated your manifold is leaking and you have found no loss of fluid i would go to another repair shop for this inspection and quote on repair issues and costs.....
Old 01-28-2008, 05:02 PM
CV joints - are fine I found out what the problem was there. That was nothing. When they Changed the Oil the moved the plastic piece to get to the oil filter and the tire was rubbing it.. Got lucky on that one.
Transmission - is fine, no Problems there.
CAT - I think is still clogged.
Lower Intake Gasket - I can see is leaking.. I don't know how we missed it in the past. I do have a small drip in the Garage but nothing really worth writing home about. I usually only have to add a quart of oil if I go 6000 miles between Oil Changes. So is the Leak causing as much issues as what they said I really don't know. I do plan on having someone else look at it. To me if the gasket is leaking on the lower intake, it would be saver to Fix than not. I got another price from a local in my area that does do great work for $550. But he agrees that, it still sounds like the CAT is clogged.
Old 01-31-2008, 01:26 PM
Had the CAT replaced yesterday and everything is back to normal.. Now I'm just hoping this did not cause othere problems that will come up later.
Old 01-31-2008, 06:59 PM
troy1 troy1 is offline
AF -Advisor
Did GM do it for free?
Old 01-31-2008, 07:34 PM
the cat that came with you car and all the other impala's were defective. if everything is operating normal now you should be fine . your oil leak is small and because of the cost just keep an eye on it. if it were antifreeze , that is serious, and would require repair........
Old 01-31-2008, 10:04 PM
tirwin88 tirwin88 is offline
Would be?
Sorry! I meant wouldnt be an issue in the future!
