#16
Re: Enthalpy tune or e-mance
eeesh. well a couple things. dont vent your BOV. its a big reason why your running rich. a MAFS measures the mass of air, not the pressure like a MAP system. so any air that you vent when you let off the throttle is air that has already been read by the MAFS and the fuel will be supplied for this air that just left your intake via the BOV. now recirculate that bitch like your supposed to. second, i hope you told enthalpy about your z32 MAFS. if you didnt, you need a retune. they operate at different levels, so your ECU wont be able to read one if it thinks its the other. thirdly, i hope your knock sensor isnt bad, but if it is i believe courtesyparts.com stocks em.
btw anyone who drives a nissan should know about courtesyparts.com factory nissan parts that might be hard to get from many local dealerships, depending on where you live.
Well its not the knock sensor. I put a new one and the code still came back, so I returned it and put the old one back in. I have continuity between the ecu and the sensor. But exactly where are the grounds located for the knock sensor? Is it the two on the last intake runner? I did tell enthalpy about the z32 maf. But the maf code only came up once. It still breaks up and backfires 4500 rpms+ at wot. At part throttle its fine. Hopefully the dyno tune with the safc will fix the breaking up at high rpm's.
ok dyno the tuning did not go well. Car was running way to lean and the afc neo couldn't correct it. Turned out the fuel filter was really clogged up bad. Now runs a whole lot better, and doesn't break up anymore at wot. Going back to dyno monday morning. Does anybody know what setting in and out on the safc, I have it on 2 and 2, is that right? enthalpy tune for 740cc z32 maf.
lol so now your tune is fine.
take the safc off before you fuck it up agian.
"A criminal hiding in plain sight ought not wave red flags lest he desires to lead the authorities right to him." |
#20
my car started acting up again, on the dyno. I made 290rwhp 320tq not getting past 4700rpm. Missing, hesitating at high boost. turned out spark plug gap was too open. I cant believe the gap would make such a huge difference. Now power is smooth to redline. Going back to dyno sometime this week. I think hp should be in the 320 range.
so it sounds like everything is starting to fall into place. now your getting an idea of how much attention to detail running a high power turbo car takes. you dont have to take the AFC off, it can be useful if you ever change a part or two in the future, or up the boost some more. but i really dont know a whole lot about using one. im not the one to ask about the settings.
