Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 01-22-2008, 05:34 AM   #16
Tinman238
Re: 94 Lumina 3.1 cranks - won't start
Originally Posted by Rub_Dr
Hey your reply set off a lightbulb. Sounds similar to what mine did b4 it just gave up. After 2 yrs of tinkering on it in my spare time it ended up being the wiring was shorted from the crank sensor to the control module. A cheap way to check that, go find one in a junk yard that still has both connectors and make a new 1 you can loop under the car and plug in. Most of the junk yards will just give you the connectors or at least they do here where im at.
At least mine is running OK for now.. just need to clean the rats nest out of the duct work so i have heat again
I'm beginning to suspect wiring more and more. I will definitley check the wiring out. Thanks.
Tinman238 is offline   Reply With Quote
Old 03-20-2008, 07:09 AM   #17
luv my lumina
similar problems here...replaced plugs and all things ya'll listed...ended up being busted timing chain.....maybe worth checking out eh?
luv my lumina is offline   Reply With Quote
Old 03-23-2008, 02:02 AM   #18
Bearwulf
Bearwulf's Avatar
Originally Posted by Blue Bowtie
A '12' is the code for no ignition reference pulse. It doesn't mean that the system is in diagnostic mode, as most web sites erroneously report.
Then maybe you should inform GM about this as they state in their manuals as well as @ the shops that this is the indication of whether or not the ALDL is working.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Bearwulf is offline   Reply With Quote
Old 03-25-2008, 04:23 PM   #19
Manowarr
This happened to my 92 lumina 3.1L V6. It would crank over but wouldn't start. They replaced a couple of coil packs and the crank sensor and it started fine after that.
Manowarr is offline   Reply With Quote
Old 03-25-2008, 08:31 PM   #20
Tinman238
Thanks for the input. Verified the timing chain is fine, checked ignition module, coils, new plugs and wires, new intake manifold gaskets, fuel injectors verified OK, new ECM, O2 sensor, crank sensor, fuel filter, etc. Seems to be that the ignition circuit is not getting consistent power. I'm thinking now that it could be something in the ignition switch or wires in the steering column. I bought a Tahoe cause I needed something that ran. Hopefully I'll work on the Lumina again in a week or so.
