Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-30-2007, 10:42 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: 420a Rebuild - Ongoing Advice
Originally Posted by david-b
I recommend going to a hardware store and picking up a piece of piping and a large C-Clamp. The piping needs to be a T pipe and you just do some trimming til it fits.
Actually here's a pic. Piece cost like $.69 or something like that. It's brass so it's solid and has a hole in the middle where you can get to the lock.
Nive Dave, I'm actually ising the compressor I rented from vatozone, lol. Luke I like the thread and pics man, awesome job...but damn thats a lot to read
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 12-31-2007, 08:30 AM
Luke Home's Avatar
Luke Home Luke Home is offline
Has anyone replaced the Hydraulic Timing Belt tensioner with this mechanical tensioner?
Link
The link above has more info on this.
1998 Bonneville SE 156,000+, Miles, Running Good So Far
1999 Camry LXE 105,000 3.0 V6 (1MZ-FE Engine), A541E Trans.
1997 EAGLE TALON ESI 2.0L L4 SFI DOHC 16V (Project Car - 140K)
Old 12-31-2007, 10:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Haven't seen one of those. The site wasn't very useful on exactly why we should switch to it and how it works. I would stick with what I know with the hydraulic. Those work perfectly fine anyways.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-02-2008, 09:01 PM
Luke Home's Avatar
Modified my Valve Spring Compressor and got all the valves out. They are all bent, both intake and exhaust.
This may be another elementary question but I am not finding any (reliable) info on the best way to remove Carbon build-up on the aluminum head. I was going to get the Block Hot Boiled at a local shop ... but he said he cannot do the head. Was thinking about purchasing castrol purple power for the head but wasn't sure if this would have a damaging effect on the aluminum. Especially in the Cam bearing areas.
Any words of wisdom here?
Old 01-03-2008, 01:28 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
I think any cleaning agent will be fine, aluminum is a pretty tough metal so I don't think it'll hurt much. I've used Engine Brite and a pressure washer before on my motors and it usually works pretty good.
95 Talon TSI AWD
97 Eclipse GST
Old 01-03-2008, 01:54 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I believe that a few people have tried the mechanical tensioner with out much luck. I would stick to the hydrolic tensioner
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-04-2008, 08:57 PM
Luke Home's Avatar
Is it necessary to remove (and Replace) all the oil and coolant plugs before getting the Block Hot Bathed?
Is it advised to replace all the oil and coolant plugs in the head on a rebuild?
Also, are the Bedplate (Bottom of the block) bolts Torque-to-Yield as well? And, of course, if they are will need to be replaced!!!??
Old 01-04-2008, 10:41 PM
I would remove all of the coolant plugs before the hot tank, but I'm not sure about the oil plugs. I've never done the plugs in the head for a rebuild, and last but not least, no, the bedplate bolts are not TTY, you can reuse them.
95 Talon TSI AWD
97 Eclipse GST
Old 01-05-2008, 09:14 AM
Luke Home's Avatar
Last night I was searching the web for more info on this motor (since my manual did not come in yet) and I found this General Information (TSB Rev.) Engine Overhaul <2.0L(420a)> manual ... which I am sure many here have already seen.
Manual Link:
In any case, on page "11D-7" of this manual the torque spec on the Connecting Rod Cap Bolts call out is 20 lbs + 1/4 turn. First off this seems low to me when I compare the torque it took to loosen this bolts (about 65-85 lbs). Does this sound right? Also, since the torque on these bolts has a similar call-out like the Cyl. head bolts (with a +1/4 turn) it makes me think that these Connection Rod Bolts are TTY bolts too. Are they? So far from everything I have read, no one has mentioned anything about replacing these bolts.
Page "11D-7" Page Link:
Old 01-21-2008, 09:30 PM
Luke Home's Avatar
A little off base here ... I have a leaky seal on the passenger side Rack & Pinion. Since the motor is out and it is easy to get too I pulled the rack & pinion out.
Question, how do I get that seal out and where might be the best place to buy just the seal?
My Haynes manual does not cover this at all.
Thanks,
Old 02-08-2008, 09:58 AM
1996EclipseRS 1996EclipseRS is offline
Manual Link:
Only the head bolts are TTY.
Also when I rebuilt my 420A I never replaced the rear main seal. Needless to say it leaks. So I would recommend replacing any oil seals especially the ones that are hard to get to such as the rear main.
Other then that id say rebuilding the engine was pretty painless. Good luck with the build!
420A
JE Forged Pistons 10:5, Crane Super Street Performance Cams, Crower Connecting Rods, Crower Valve Springs, Port & Polished Head, A'PEXi SAFC II, DigiMoto Datalogger + more, Prothane Motor Mounts, Ebay Header =(, Stock Exhaust, busted driver side window, stolen SAFC(tear), blown tranny
-1984 Mercedes Turbo Diesel 300CD (270k)
-1992 Ford F-150 302 (180k)
Old 02-08-2008, 01:26 PM
MazdaX's Avatar
MazdaX MazdaX is offline
Caustic solutions used in hot tanks at machine shops will clean that shit spotless.
2004 Mazda 6i
1997 Tahoe
Old 02-09-2008, 06:44 PM
Luke Home's Avatar
Originally Posted by 1996EclipseRS
...So I would recommend replacing any oil seals especially the ones that are hard to get to such as the rear main....
Yes ... we purchased the whole engine gasket kits (upper & lower) and are replacement all seals/gaskets.
We almost have it all back together. We are waiting on the Rack & Pinion Gasket kit so we can rebuild it before putting the engine back in. The rack & pinion is much easier to put in with the motor out.
