#16
I swear by using Krylon interior/exterior paint! that shit works AWESOME!
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
#17
heres my old interior using krylon:
it did chip cause of the cold weather otherwise it woulda worked out fine...clear coat is what makes it chip
blah |
#18
like i said, make sure the paint you use is a little bit flexible and don't rush it makin it dry. The faster it drys, the less flexible it is.
Tony 91 Civic Sedan DX - Stock 287k Miles |
#19
i hear AEM vinyl paint is the best u can get
blah |
#20
yo leigh, did you throw your interior back to stock, or repaint it or what?
AF Bay Area Crew ![]() 97 Toyota T100 xcab 3.4l v6 5spd 2wd |
#21
My door panel has extreme sun damage. It is so bad it went all the way to the core of the door, anyone know how i should fix it?
CRX Si |
#22
The how-to that I wrote is ONLY to be used for painting hard plastice pieces, NOT vinyl (door panels/dash, etc).
Also, don't use solvent based cleaners to clean the painted pieces once they are done... also Armorall, etc will rub the paint off... 90civicrider says that he uses something called "spray nine" that works perfectly... hit him up for more details.
so do i use the clear coat after the enamel?
and what should i use to paint my dash then i think im just gonna try it the same way
anyone?
Here's Mine.
I used Painters Touch Primer, Krylon Interior/Exterior base coat, Tremclad Clear Coat.
#26
Im just waiting till schools over then I will work ft and pour $$$$ into my car...I am almost certain to be kitted and turboed by the end of summer heh
blah |
#27
does anyone think red/white would look good togeather?
and does it really matter if i do this in my garage while its like 10 degrees or less outside since im stuck here all day (i hate the snow arg)
i mean all i was gonna do was sand all my shit in the house then do the primer today but tomarrow is the painting part
i don;t think the cold will make it crack or anything
where ever you paint it should be warm otherwise it will not stick and it will crack. Warm it up somehow
#30
ok what about this i spray it outside and then bring it all inside (on some wood so not to touch it)
i want ti just spray it in my basement but my moms all like no bitch then the smell will go all over the house im trying to tell her that it won;t but she';s being a wanker
