Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 02-01-2003, 12:02 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
*sigh*... no... they're not the same motor.
the 5.3liters is 327cid. Not exactly a LS1 which is 5.7liters or 350cid. It is scientifically impossible to be the same motor. If you're selling me Vortec motor parts for a 5.3liter GM V8... and Im asking for LS1 Parts... I'd probably throw a camshaft at your head.
It is physically Impossible for them to be the same Motor.
LS1 is an All Aluminum 6-Bolt Main, uses a composite (plastic) Intake manifold. Not mention the Block is half-an-inch shorter than a regular GM cast iron block.
Other Odd tid bits about the LS1:
The ignition hardware is mounted atop the valve covers. Each cylinder has its own coil and coil driver assembly and a short plug wire connects each a spark plug. The reasons for moving the coils to the covers are simple: 1) less spark energy is dissipated by short spark plug wires so more energy available at the plug, in fact, it increases nearly 100% and 2) shorter plug wires reduce radio frequency interference with on-board computers and the sound system. For the lazy: It means the LS1 runs a distributorless ignition.
And lets not for get Firing Order... Gone is the time-honored 1-8-4-3-6-5-7-2 sequence. This new engine fires 1-8-7-2-6-5-4-3. The cylinders are numbered the same: left bank: 1-3-5-7 and right bank: 2-4-6-8. The reason for the new firing order is better idle stability and less vibration.
For the lazy: It means its a totally new designed motor and cannot be a standard GM block.
Most notable is that this engine is the first two-valve V8 to reach the one-net-horsepower-per-cubic-inch plateau. That is a monumental engineering achievement.
Vortec GM V8 Motor Facts.
Standard GM 350 Castiron Block
The Vortec heads are totally different from that of the LS1. Just go look at the GM performance parts catalog. You need to order a seperate Intake Manifold to fit Vortec heads. There are zero interchangeable parts between the two motors.
I cant believe you're argueing the fact that the two motors are remotely similar. I mean for crying out loud. Just look at them.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Need info, will probably be buying soon. Brand new. bulldogue Tundra 3 05-29-2008 10:19 PM
Will my engine die soon? nerij M Bodies 3 03-18-2006 08:04 PM
Things That Will Be For Sale Soon blkef Classifieds 1 01-20-2005 12:23 AM
Will Michael Jackson die soon? Formula400 COMPLETELY off-topic 28 12-12-2003 02:37 PM
will there be to AM in the new James Bond fil Menu dei Motori General Discussion 7 11-04-2002 10:13 AM
