Old 01-06-2008, 08:17 PM
CD Smalley CD Smalley is offline
Re: Steering position sensor EVO
Thank goodness for old threads.
Now I know what to do to fix this problem on my 97! Off to GMPartsDirect to order the part now...
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 02-03-2008, 03:14 PM
andrewszeb andrewszeb is offline
I found the sensor at O'Reilly auto parts under (strg sensor) item # 31025 or 6031025 it was right there on the shelf for 39.99. I called around and they said dealer would be the only way to get it. Not the case. Thank you all for saving me once again.
Old 03-28-2008, 12:26 AM
MikeQ MikeQ is offline
I have a 1999 Tahoe that has the symptoms of a faulty EVO steering sensor. However, I like the feeling of the fully boosted steering. Rather than replace the steering sensor, can I disconnect the wires to the variable orifice solenoid valve on the power steering pump so it defaults to full boost alll the time? Will this cause an ECU computer fault code or cause any other adverse reaction?
Thanks for any help.
MikeQ
Old 04-25-2011, 12:59 PM
Big Boy toy chevy Big Boy toy chevy is offline
Does the 96 2dr tahoe sport have this sensor
Old 04-25-2011, 07:03 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
I think it was only 97 and up. I am a little out of the loop, hopefully someone here can answer your question for sure.
John
Old 04-26-2011, 11:14 AM
777stickman 777stickman is offline
The easiest way to tell is to look at the back side of the steering pump. If you have wires going there then you have the EVO system.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
Shortbus (04-26-2011)
  #22
Old 02-27-2012, 04:29 PM
K Walker K Walker is offline
I found the sensor on Amazon for $39.
http://www.amazon.com/Motormite-Steering-Sensor-trucks-94-2004/dp/B000F2EPIQ
I just ordered it so I haven't verified fit.
