Old 12-20-2002, 04:16 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
stick your hand on the bottom of the resevior and find out if its leaking, or check where you saw the stain and find out where its leaking form. maybe you just need a new resevior.
Old 12-20-2002, 02:16 PM
88CRX's Avatar
88CRX 88CRX is offline
is a leak really gonna cause it to overheat and the heater to stop working?
zc powa
short ram intake
dc sports header
2.25 Magnaflow exhaust
h/r race springs
Old 12-20-2002, 05:52 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
Originally posted by Melt
Hows the b18 swap coming?
I couldn't find a b18 that was cheap, so I decided on getting a b16. I should have it by the end of the month, and it'll be swapped in by the end of January if all goes according to plan. I'm gonna get the turbo in a few months after I save a bit more money, but my goal will be to have the turbo installed by May or June.
10 PRINT "MARC-OS 0WNZ J00!!!"
20 GOTO 10
RUN
4/8/04 - My CRX is officially dead, RIP Lucy
Old 12-20-2002, 10:04 PM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Yes, your not only running out of coolant but your also not getting a good coolant pressure to circulate it right. If im not mistaken most heaters run off a coil heated by the hot coolant coming off the engine, someone correct me if im wrong but im pretty sure im right
