Old 12-12-2007, 04:11 PM
Robi J's Avatar
Robi J Robi J is offline
Re: MFH Ferrari 2003 GA, 1/20 WIP
Clean and precise (lovely connectors !), sexy pictures. Sooooooo nice, Sasa.
R
Old 12-12-2007, 04:22 PM
jaykay640 jaykay640 is offline
Great work and good to see one of those Hiro Ferraris being built!
Gotta get my running projects done to attack one of these!
I'm always a bit scared when i see you guys build an engine right down to the details without having started test fitting everything with the rest of the car:-) I guess i've had my fair share of bad experiences so i'm test fitting and building as much as i can before adding any paint but then a Hiro kit is pobably as safe as you can be in terms of fitment! :-)
Looking forward for new updates!
Old 12-12-2007, 04:30 PM
robrex's Avatar
robrex robrex is offline
Simply stunning Sasa!
Rob
Old 12-12-2007, 10:07 PM
kanedge kanedge is offline
Beautiful detailing so far, look forward to more.
Old 12-12-2007, 10:50 PM
klutz_100's Avatar
Boj Boj za narod svoj!!!
Looks just stunning, Sasa.
Outstanding work
Old 12-13-2007, 02:28 AM
sjelic's Avatar
sjelic sjelic is offline
Thank you guys
Jay I sure needed to test everything and even then there were few problems that appeared afterwards, main problem is engine cover that I will leave open anyway, so I just reshaped it to have some kind of fit.
Everything else need just a bit of a push to fit in place
Sasa Jelic
SCALEMAKERS
Old 12-20-2007, 07:16 AM
sjelic's Avatar
Not much to add, I spent some time in preparing body for paint, put it all in primer and I just wait for it to cure well (white metal need a lot of care to make nice and smooth).
In the mean time I have made seat belts.
Those are strange combination.
First off all MFH set looks to small, to narrow for main tensioner, I have replaced them with SMS ones, fasteners on top are from CM, central buckle is also from SMS while material for main shoulder belts is from a gift wrap, just a bit thicker then MFH one.
I have put it all together and fitted to body (slight reshaping of side panels were needed to fit properly).
I have also made the intake cone, sanded the molded rivets that will be replaced with real ones.
Thank you for watching.
Sasa Jelic
SCALEMAKERS
Old 12-20-2007, 07:22 AM
klutz_100's Avatar
Quite simply it looks great, Sasa
BTW what are you using to glue the folds in the ribbon/straps?
I used 2-sided scotch tape last time which was quick and clean but I am only 80% happy with that method. Your straps look much better
Old 12-20-2007, 07:25 AM
hrmodeler's Avatar
hrmodeler hrmodeler is offline
Send a message via ICQ to hrmodeler Send a message via MSN to hrmodeler
That's a killer one! Apsolutly beauty!
Zeljko Segin
http://www.hrmodeler.com - Fast wheels - my pages
My current project - .....
flhansen's Avatar
flhansen flhansen is offline
Hi
Lovely! Like the look of the exhausts. Got exactly the right color!
Flemming
Old 12-20-2007, 07:33 AM
sjelic's Avatar
Now this is where I spent most of the time, first I thought the same thing (double glue tape), I took one test piece and fixed it, but like you said...it is good but....
Then second thing that is much worse when you first think of it, CA glue, of course material will suck it, change color. But I had to try, so applied the glue only on side that will not be visible (I used Loctite precision CA that is very thin) , put a bit, waited for few moments to suck in to material and then folded. Part of the glue went through on the visible part of the belt and did exactly what I was afraid of, stained material. When it was all dry I took satin Microscale clear, diluted it with water and applied with brush, fixed the belts on the seat and repeated clear once more. When it was dry there were no more stains.
Sasa Jelic
SCALEMAKERS
Old 12-20-2007, 09:09 AM
godfather23's Avatar
godfather23 godfather23 is offline
woooaaah, I like what I see. You seem to master this little sucker quite well. Keep up the great work.
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 12-20-2007, 03:15 PM
Robi J's Avatar
Fantabulous cockpit Sasa !!!
Robi
Old 12-20-2007, 03:24 PM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
Just beautiful... nothing more to add...!
Ohh wait there's something more what glue go you use for the resin and white metal parts?
Old 12-20-2007, 03:33 PM
ilferraristarosso's Avatar
ilferraristarosso ilferraristarosso is offline
Amazing work,everything is well done,the cockpit is perfect.
