| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
#16
Re: Won't start without starting fluid?
My car actually primes the pump when you turn the key on. I think some turbo model cars did this and others did not.
Your fuel line is not going to hold pressure unless the pump is on. I think the stock pump may have been able to hold a little bit but the aftermarket pumps wont hold any. Like I said it only take a second to pressurize the lines when the pump turns on so I dont think that is your problem. So the car as of now wont crank? Hw much pressure are you getting while cranking?
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
#17
I think that it may be a 1g/2g difference... If I recall correctly, my 95 Talon primed in accessory mode... but the manual says it has to be cranking for this 1g.
1990 GSX PTE SC6152e, tubular manifold, FIC 650's, wiseco/eagle internals, dsmlink, TRE tranny, Apexi dp and cat-back, Apexi EGT and Boost Gauges and Turbo Timer, Megan Racing FPR, Walboro 255 Pump and much more to come. |
#18
So after you primed the fuel line the car ran fine? Did you drive it around or let it idle? When you cut it off would it crank right back up?
#19
For reference the 420a (not sure what else, most cars should do this also) "primes" or pressurizes when key is turned all the way on before the engine gets cranked. It's still technically under pressure due to the fact that there is no place for it to go. The injectors are closed, the pump is off, and the lines are still full of fuel. You obviously want the pump to turn on and to pressurize the system before the motor starts cranking or it'll take even longer to start.
Just to clear that up.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
#20
After I prime it and use ignitor fluid, the car will start and run and we can drive it around.... if we turn it off and then try to start it back up, it'll start, but it starts kinda hard... Dave... my question is this... since my fpr gauge is dropping to 0 after it's set for a while... where would you suppose the fuel is going? I was thinking it was flowing back into the tank due to a faulty fuel pump, but that doesn't seem to be the case. I'm going to change the fuel filter for shits and giggles. Other than that, I really have no clue at this point.
#21
The fuel goes back into the tank. I believe the pumps have some sort of check valve in them but the pressure is still going to leak out.
#22
I don't understand that last post at all.... the fuel goes back into the tank.... but there is a check valve so that the fuel won't go back in the tank? I'm very confused.
#23
There is sort of a check valve system I THINK, but the pressure still leaks out. Its not suppose to stop it completely.
#24
If the fuel pumped back into the tank after shut off, when you go and disconnect a fuel line even after the car has been sitting for a long time, there would be no fuel in the lines then. Not the case. Before you touch the fuel system (ie fuel filter change) you have to depressurize the fuel system by opening the gas cap, disconnecting the fuel pump, and starting the car numerous times. This works out all the pressure in the lines then and makes it accessible.
If all the fuel went back in the tank after shutoff, this whole process would be unnecessary. So the gauge reads 0psi after a while or how is that working? Did you check the gas cap and see if it actually tight or leaking at all? It seems like there's something causing you to lose pressure, like maybe it is going back in the tank then, especially if there's no puddles or leaks right?
#25
Well.... I halfway don't want to post this because it makes me look like a retard, but since you guys helped so much, I feel that you deserve some resolution. The fp gauge is still bleeding back to zero, but that may be because I don't have the fuel pump completely back on (air tight with sealant), but the car now starts still. The problem was that my ignition timing was way off... I mean WAY off. There you have it... perfectly good running dsm (unheard of) > idiot mechanic.
#26
Glad you got it running, thats all that matters.
#27
#28
There are no words to express how frustrated I am right now... we let the car sit over night and now it won't start again... I love dsm's so much.
#29
Okay... I think I found the problem... the injectors are firing in the order of 1-2-3-4... the firing order should be 1-3-4-2. The injectors and ignition should be synched right? It looks like someone may have done a little rewiring to the injectors, should I hook them up so they squirt 1-3-4-2 like the firing order?
