Old 12-17-2007, 06:46 PM
blazeracer blazeracer is offline
Re: 02' GTP problem
My car was running like doo doo.. miss firing, stalling at red lights, I bought a scanner because I had no check engine light and 5 codes came up, to include the MAF sensor and the check engine light. (yes, there is a code for that). Replaced the MAF sensor and two other codes went away with it and the car runs like a dream now.. still working on the last code in another post.
Old 12-17-2007, 07:13 PM
daejuanj daejuanj is offline
Send a message via ICQ to daejuanj Send a message via AIM to daejuanj Send a message via MSN to daejuanj Send a message via Yahoo to daejuanj
Re: 02' GTP problem
Originally Posted by lil_nages22
Be careful with assuming it is the MAF sensor. I just recently replaced the MAF sensor in my car for similar problems, but still get the same problems. Could possibly be something else, but it is worth a shot.
Thanks for the tip, I'm gonna see what Carmax has to say.
Old 12-18-2007, 06:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 02' GTP problem
Since you say the noise you were hearing was mis-diagnosed, I would agree it may be a MAF issue. If you have a CAI or reuseable (K&N, Air Hog, etc...) type air filter installed, the chance it's a MAF are very high. The oil used in those filters can get sucked into the MAF filiment causing your symptoms.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 12-18-2007, 08:15 AM
Re: 02' GTP problem
Nope all stock. No aftermarket parts
Old 12-18-2007, 03:57 PM
richtazz's Avatar
Re: 02' GTP problem
Since it runs good with the MAF disconnected, I'd say you found your problem. Buy a new one from ZZperformance or an AC-Delco one. Reman ones from Standard and Cardone are basically junk.
